PlexAmp for Android Suggestions
Hi!
First of all - love the app so far! I understand that Android Auto & Casting support will be on its way so thank you :slight_smile:
Just a couple of suggestions…
On the All Music section, you can sort the artists by title, date last played etc… but you cannot sort the albums/tracks in the same way - would be fantastic if you could see an A-Z list of both of these!
Also, on the playlist view, I’d like to be able to do two things:
Firstly, have a fast scroll bar at the side so it’s easier to jump to the middle or bottom of the longer playlists.
Also, have an “edit playlist” button, which allows you to sort your playlist in the same way we can sort artists: by title, by date added, by play count, etc.
This would be perfect! Thanks for your hard work :slight_smile:
Thanks for the suggestions! Editing playlists is definitely on the list :sweat_smile:
