Plexamp for Raspberry Pi v2.0 beta 2 not connecting to music library
Hey I got plexamp running on my rpi 3b+ and it doesn’t connect to my server library.
I used the client id info from a Plexamp v1.1 for Mac (which also can’t find my server library). Plexamp v3 for Mac can find my server library so it doesn’t seem like server settings.
Any ideas on how to get plexamp on my rpi to connect?
Probably Plexamp raspberry pi certificate expired
Thanks for the quick reply! I would’ve never thought to check for that! I’ll take a look and report back soon.
If that doesn’t work for you, I had to fix some other things, to get mine working for the first time earlier this week, as described here: Plexamp for Raspberry Pi - How to create a new server.json file now older desktop versions of Plexamp no longer work - #6 by IvanKaramazov . Even before that I had to manually add the server info to my server.json, since the old desktop apps also can’t connect to the media provider list anymore.
Hey Ivan! Error 406 was exactly what I was seeing when I got systemctl status of my rpi Plexamp instance. What did you do to get it working?
The rpi is connecting to my own server so whatever I need to change, I’m willing to give it a shot.
I tried the certificate solution and no luck.
Hi DanD. I posted the code and instructions on github here: GitHub - IvanKaramazov/rpi_plexamp_hack. Please lmk if that works for you or if you need any further info. Good luck!
