Plexamp does play Music louder than the apples native Music app. How come?
One thing that I did realize it that tracks then start clipping (did a comparison with Boards of Canada - Naraka and the kickdrum is getting distorted on my own 320kbit MP3 on high volume on Plexamp, but doesnt with the native HQ stream).
you have cranked the sliders on the EQ totally up. Disable it and see if it makes a difference.
you have set a value for Replay Gain preamp larger than 0 dB
you have disabled loudness levelling
you have a track within the affected album which contains a digital glitch, thus offsetting the album loudness analysis – and therefore all other tracks within that album as well. This tends to happen more often with “Frankenstein albums”, i.e those which were created by combining tracks from disparate album releases
The MP3 is the original from the distributer Warp. Same situation now that I tried a FLAC.
Also tried disabling loudness leveling but no change at all.
But it also applies to other tracks, so it cant be specific to this album. Could it be a iOS system setting? I did just check all setting I could find including Accessibility and there seems to everything how it was initially set.
So, I identified the reason. iOS has an option to activate a loudness limiter under “Sound & Haptics” - “Headphone Safety”. Odd thing is it is already active for the Music app and limiting at 95dB without having the option chosen.
Here’s a screenshot showing it in its active state:
