Plexamp merging artists with similar, but different, tagged artist fields
Okay, so it isn’t with those albums, but I did notice that Plex had done something similar with multiple albums I have, tried to fix it, and it exhibited the behavior I described.
The logs are attached.
Plex Media Server Logs_2024-12-28_17-20-48.zip (4.7 MB)
Some details:
  1. The album in question is Speak to Me by Julian Lage. Plex insists that the Artist is Julian Lage Group, for which I have exactly one album. (Plex insists this for all 7 albums that should be Julian Lage albums; I have one album that is, in fact, by Julian Lage Group.)
  2. I have Prefer Local Metadata checked for the library in question.
  3. In Mp3tag, the Artist and Album Artist are both Julian Lage, with no mention of Julian Lage Group.
  4. When I change the Artist in Plex from Julian Lage Group to Julian Lage, it briefly “moves” it to Julian Lage, and then, within a matter of seconds, updates it and “moves” it back to Julian Lage Group (the files don’t move, just the organization within Plex.)
  5. The album is located in …/Music/Julian Lage/Speak To Me.
So, while it’s not the specific albums in question in this thread, I believe it is exactly the same behavior described.
i think i have a server fix for this, will take a while to work through review and release.
Great - thanks for taking a look at it and the quick response.
Curious where this is at and if I’m experiencing the same issue.
I’m seeing stuff like this where I add a CD, and it split it into 2+ albums even though the Album Artist is the same and the album names are exactly the same and all the files are in the same directory:
This has happened since I’ve been using Plex for Music, but it’s really annoying as I rip more CDs and buy more digital tracks as it doesn’t seem to be paying attention to the tag info nor is the “Prefer local metadata” (which I have checked) seeming to work.
See if some of the tracks are missing the track # or disc # tags.
Those were set up by Picard (MusicBrainz), so I don’t think that’s even possible. I didn’t see anything funky either.
On the other hand, I noticed that “album artist” isn’t the only thing required, you also want “total discs” or Picard won’t add the disc number prefix in multi-disc sets.
I’m betting there are some other hidden things we’d need to consider that aren’t obvious.
