Plexamp mpris bug
I’m using debian bullseye, with i3, and a desktop bar called i3status-rust that enables a block in the bar to “interact” with clients that implement like Plexamp the mpris interface.
I can for instance, while watching a youtube video in chrome, use the middle whell button of my mouse to advance the movie : under the hood the command would be :
busctl --user call org.mpris.MediaPlayer2.chromium.instance2962464 /org/mpris/MediaPlayer2 org.mpris.MediaPlayer2.Player Seek x 100
Should I want to do the same on the plexamp client, I would do the following, and it unfortunately crashes, see the trace:
❯ busctl --user call org.mpris.MediaPlayer2.Plexamp /org/mpris/MediaPlayer2 org.mpris.MediaPlayer2.Player Seek x 100
Call failed: Service error: The service threw an error.
TypeError: p.toNumber is not a function
    at F.value (/tmp/.mount_PlexamWiaGm0/resources/app.asar/main.js:2:339342)
    at handleMessage (/tmp/.mount_PlexamWiaGm0/resources/app.asar/node_modules/dbus-next/lib/service/handlers.js:305:28)
    at handleMessage (/tmp/.mount_PlexamWiaGm0/resources/app.asar/node_modules/dbus-next/lib/bus.js:100:14)
    at EventEmitter.<anonymous> (/tmp/.mount_PlexamWiaGm0/resources/app.asar/node_modules/dbus-next/lib/bus.js:110:9)
    at EventEmitter.emit (node:events:526:28)
    at /tmp/.mount_PlexamWiaGm0/resources/app.asar/node_modules/dbus-next/lib/connection.js:102:14
    at Socket.<anonymous> (/tmp/.mount_PlexamWiaGm0/resources/app.asar/node_modules/dbus-next/lib/message.js:55:9)
    at Socket.emit (node:events:526:28)
    at emitReadable_ (node:internal/streams/readable:578:12)
    at processTicksAndRejections (node:internal/process/task_queues:82:21)
You could try using playerctl.
I have also noticed that Plexamp’s MPRIS controls do not work consistently in KDE, although they’re fine in XFCE… Playerctl to the rescue. :wink:
yes but it is the very same error, that doesnt do it since the client fails at implementing correctly mpris :wink:
❯ playerctl position 5+
Could not execute command: GDBus.Error:com.github.dbus_next.ServiceError: Service error: The service threw an error.
Looks like we weren’t implementing the Seek action over MPRIS. This should be resolved in the next release. Thanks for the detailed report!
Thanks for the fast solving @aubrey.wodonga !
greetings @aubrey.wodonga I just tested 4.6.2 and it seems it has not the issue fixed, at least for me:
    at F.value (/tmp/.mount_PlexamEbwaw7/resources/app.asar/main.js:2:343120)
    at handleMessage (/tmp/.mount_PlexamEbwaw7/resources/app.asar/node_modules/dbus-next/lib/service/handlers.js:305:28)
    at handleMessage (/tmp/.mount_PlexamEbwaw7/resources/app.asar/node_modules/dbus-next/lib/bus.js:100:14)
    at EventEmitter.<anonymous> (/tmp/.mount_PlexamEbwaw7/resources/app.asar/node_modules/dbus-next/lib/bus.js:110:9)
    at /tmp/.mount_PlexamEbwaw7/resources/app.asar/node_modules/dbus-next/lib/connection.js:102:14
    at Socket.<anonymous> (/tmp/.mount_PlexamEbwaw7/resources/app.asar/node_modules/dbus-next/lib/message.js:55:9)
Huh, that’s disappointing. It seems to be working fine on my end, but I’ve got a few ideas.
Leave it with me and I’ll look into it. Apologies for getting your hopes up prematurely :sweat_smile:
hehe no worries, let me know you need me to send logs, whatever you’ll find useful !
greetings @aubrey.wodonga ! any news on this ? thanks :slight_smile:
4.7.0 still has the issue @aubrey.wodonga
Apologies for the delay, I haven’t forgotten. It turns out the proper solution is non-trivial and requires some more work to unblock. Hoping to have a solution soon :crossed_fingers:
