Server Version#: 1.25.4.5426-eb46d070e
Player Version#:no
Hello,
I’m looking for a working version on Plexamp for my “old” Macbook (macbook5,2).
MacOS 10.9.5.
Thank you
Have you looked on plexamp.com ?
Yes I have, of course.
The proposition for download is Plexamp v3.9.1, supposed to work on macOS 10.9 or newer (64 bits). The Intel Core 2 duo is 64 bits.
When I want to drag in apps folder, the message is : OS X 10.11 required !
After some digging, unfortunately it appears you’re right, and some of Plexamp’s dependencies don’t support macOS versions below 10.11.
plexamp.com has been updated to reflect this. Sorry for the confusion.
Too bad !
Thanks anyway.
Is there not a previous version of Plaxamp working on macOS 10.9.5 ?
