What is the Show on All Desktops supposed to do? I was hoping that when I switch virtual desktops that the music player would be on them all so I can easily access it without switching desktops to get to it.
That’s the idea, yeah
I have it enabled but it doesn’t work.
You might need to be a bit more specific. What OS?
This is Windows 10 Pro 1909. I have 4 virtual desktops configured. I opened Plexamp on Desktop 1 but the app is not visible on any other desktops.
Ah, sorry, that actually doesn’t work on windows and documented as such, will remove.
This is actually built into Windows itself. If you win-tab you should get an overview of all you applications on the active desktop. Right click on any application and you can select ‘Show this windows on all desktops’.
Well I guess you learn something new every day. Thank you.
