PlexBMC + Helper only lokal?
Hey Guys
I have a little problem with my PlexBMC.
I have done every thing from this post https://forums.plex.tv/topic/106593-plexbmc-xbmc-add-on-to-connect-to-plex-media-server/
but i`m not able to start a stream from my anrdoid plex app.
The app find the XBMC Player and when i start a stream xbmc says "start Streaming" an nothing happens.
My Plex-Server is not hostet in my lokal Lan, but it have a static IP. The connection over xbmc an my android app is established with a plex account (not the server account)
in the xbmc.log file i found this
17:05:13 T:2602632208 NOTICE: ===== PLEXBMC START =====
17:05:13 T:2602632208 NOTICE: PleXBMC -> Running Python:sys.version_info(major=2, minor=7, micro=3, releaselevel='final', serial=0)
17:05:13 T:2602632208 NOTICE: PleXBMC -> Running PleXBMC: 3.4.6~beta3
17:05:13 T:2602632208 NOTICE: PleXBMC -> FullRes Thumbs are se to: false
17:05:13 T:2602632208 NOTICE: PleXBMC -> CWD is set to:/home/pi/.xbmc/addons/plugin.video.plexbmc-3.4.6beta3
17:05:13 T:2602632208 NOTICE: PleXBMC -> Running with built-in ElemenTree (debug).
17:05:14 T:2602632208 NOTICE: PleXBMC -> Platform: Linux/RPi
17:05:14 T:2602632208 NOTICE: PleXBMC -> Flatten is: 0
17:05:14 T:2602632208 NOTICE: PleXBMC -> Settings streaming: 0
17:05:14 T:2602632208 NOTICE: PleXBMC -> Setting filter menus: true
17:05:14 T:2602632208 NOTICE: PleXBMC -> Setting debug to true
17:05:14 T:2602632208 NOTICE: PleXBMC -> Setting stream Control to :PLEX CONTROL (1)
17:05:14 T:2602632208 NOTICE: PleXBMC -> Force DVD playback: false
17:05:14 T:2602632208 NOTICE: PleXBMC -> SMB IP Override: false
17:05:14 T:2602632208 NOTICE: PleXBMC -> Script argument is['plugin://plugin.video.plexbmc/', '48','?mode=5&force=171289&url=http://my.server:32400/library/metadata/222']
17:05:14 T:2602632208 NOTICE: == ENTER: get_params ==
17:05:14 T:2602632208 NOTICE: PleXBMC -> get_params: Parameter string:?mode=5&force=171289&url=http://my.server:32400/library/metadata/222
17:05:14 T:2602632208 NOTICE: PleXBMC -> Detected parameters: {'url':'http://my.server:32400/library/metadata/222', 'force': '171289',
'mode': '5'}
17:05:14 T:2602632208 NOTICE: PleXBMC -> Mode: 5
17:05:14 T:2602632208 NOTICE: PleXBMC -> URL:http://my.server:32400/library/metadata/222
17:05:14 T:2602632208 NOTICE: PleXBMC -> Name:
17:05:14 T:2602632208 NOTICE: PleXBMC -> identifier: None
17:05:14 T:2602632208 NOTICE: PleXBMC -> token: None
17:05:14 T:2602632208 NOTICE: == ENTER: playLibraryMedia ==
17:05:14 T:2602632208 NOTICE: == ENTER: gettranscodesettings ==
17:05:14 T:2602632208 NOTICE: == ENTER: getXML ==
17:05:14 T:2602632208 NOTICE: == ENTER: getURL ==
17:05:14 T:2602632208 NOTICE: PleXBMC -> getURL: url =http://my.server:32400/library/metadata/222
17:05:14 T:2602632208 NOTICE: PleXBMC -> getURL: header = {}
17:05:14 T:2602632208 NOTICE: PleXBMC -> Authentication error on server[my.server:32400]. Check user/password.
17:05:14 T:2602632208 NOTICE: PleXBMC -> Server [my.server:32400]offline, not responding or no data was receieved
17:05:14 T:2602632208 NOTICE: ===== PLEXBMC STOP =====
if i start the stream direkt over xbmc in this line
i found a token. could this be the reason ???
and if it is ... how could i fix this problem?
i also tryed a lokal plex-server. and here every thing works fine.
i hope some one could help me ;)
Aha! So is this why I don’t get my non local PLEXBMC box appear on my PMS??? It’s remotely connected to my server and the helper needs a tweak???
