PlexConnect command not found
And this is what I got after running the apt-get -f install:
Apple-TV:~ root# apt-get -f install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following packages will be REMOVED:
  sqlite3-lib
0 upgraded, 0 newly installed, 1 to remove and 1 not upgraded.
After this operation, 12.3kB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 1384 files and directories currently installed.)
Removing sqlite3-lib ...
So it looks like this removed sqlite3-lib which is causing the current error?
Install that deb from my Dropbox then install python and continue the guide. Sometimes these atv’s can be weird but with the instructions you should be able to figure it out. Welcome to unix :wink:
Okay, almost there...I'm up to installing python and am now getting this:
Apple-TV:~ root# dpkg -i python_2.7.3-3_iphoneos-arm.deb
(Reading database ... 3559 files and directories currently installed.)
Preparing to replace python 2.7.3-3 (using python_2.7.3-3_iphoneos-arm.deb) ...
Unpacking replacement python ...
dpkg: dependency problems prevent configuration of python:
 python depends on libffi; however:
  Package libffi is not installed.
dpkg: error processing python (--install):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
 python
Apple-TV:~ root#
Is there something else I need to install or is that libffi in thepython_2.7.3-3_iphoneos-arm.deb?
Is there a thread with further instructions for this install process?
Thank you!
Also, I SFTP your files onto the ATV2.  Does it make any difference where on the ATV2 I installed them?  I reinstalled all of your files after I was having issues.
Looks like I got it figured out.....Thank you for the help everyone, much appreciated!
:slight_smile:
Your atv is now portable also. Bring it anywhere and you can view all your home and shared plex content. Pm me if you want to trade myplex libraries. Just sign into http://Plex.tv then goto severs and edit sharing and add me if you wish and I will do the same.
wahlman.j
