PlexConnect works great. Also by installing the UnSupported AppStore, I am able to get LetMeWatchThis, which also works great, except for the LetMeWatchThis Search function which does not work at all from the Apple TV (though works fine if I go to the computer running Plex Media Server and search there). On the computer, I can go to the LetMeWatchThis Search, and type in searches for films or tv shows etc. But when I go back to the living room and sit down with my bluetooth keyboard, and go into Trailers (Plex) > Channels > LetMeWatchThis > Films > Search, the Search just sits with the spinning ball and has has never worked for LetMeWatchThis since I've been using PlexConnect (my workaround is to go to the computer, search for films, add them to the Favorites list, then go back to the TV, go to the Favorites list and start the film ... i.e. what a hassle !).
- Could people say whether they are able to use the Search function for LetMeWatchThis FROM THE APPLE TV ? (it works fine if I go to the computer and open Plex there, but it's quite annoying to not be able to search directly on the Apple TV with a bluetooth keyboard !)
- I'm pretty sure this will not work for anyone, as I've found the same behaviour on an Apple TV 2 and an Apple TV 3, so does anyone have any advice, fixes etc ? Hopefully someone knows a workaround as this would be great if it could be fixed ! :)
