PlexConnect on a NAS drive (ReadyNAS).?
I’m using terminal in OSX to run plexconnect on the readynas…
Has anyone managed to get this to work and be able to close terminal yet.?
Have you tried:
nohup sudo ./PlexConnect.py &
I'm using terminal in OSX to run plexconnect on the readynas..
Have you tried:
I'm having the same issues. Tried the above and no success for me..
I get:
"nas-EA-28-8F:~/PlexConnect# nohup sudo ./Plexconnect.py &
[1] 4613
nas-EA-28-8F:~/PlexConnect# nohup: ignoring input and appending output to `nohup.out'
and nothing happens after that. i try and load trailers app and it just says 'trailers is unavailable. try again later.'
Can anyone help.
Using ATV3 5.2 && ATV2 5.0.(?) + Terminal in OS X. Readynas pro 6
Have you tried:
Me neither... :o(
Can someone help? PlexConnect is so good and I want to upgrade my ATV2 for the ATV3 but wont if i can't get the program to run without needing terminal open
Can you try screen ./PlexConnect.py
I have tried screen and it appears to not be installed on the NAS..?
When I try and install i get:
nas-EA-28-8F:~# sudo apt-get update
Hit http://www.readynas.com 4.2.23/ Release.gpg
Ign http://www.readynas.com 4.2.23/ Translation-en_US
Ign http://www.readynas.com 4.2.23/ Packages/DiffIndex
Hit http://www.readynas.com 4.2.23/ Packages
Reading package lists... Done
nas-EA-28-8F:~# sudo apt-get install screen
Building dependency tree
Reading state information... Done
E: Couldn't find package screen
nas-EA-28-8F:~# sudo apt-get install tmux
E: Couldn't find package tmux
nas-EA-28-8F:~#
What am I doing wrong?
Please be patient I am a total newbie at the whole NAS thing.  :blink:
I have a readynas 314 and would love to get plex connect on it. I have read though that I cannot get .bin files on it as it only takes .deb files. So, I have no idea how to get the Git or plex connect on it. I have got python on my machine but thats as far as I can get.
I have looked for step by step guides (as that is the level I am at) but no joy. I am willing to have a go at anything to get it working but it needs to be in basic, newbie terms! :D
Any help is much appreciated
Cheers
Try first to modify the list of packages in /etc/apt/sources.list
add those lines:
deb ftp://ftp.us.debian.org/debian stable main contrib non-free
deb http://security.debian.org/ stable/updates main contrib non-free
Then try again:
sudo apt-get update
I have not tested so cannot guarantee that it will work (I don't need to use screen since the terminal problem is only when using ssh from MacOS apparently)
Cheers
To install git on OS6 there are general debian instructions that you can get on the web, see this post:
http://www.readynas.com/forum/viewtopic.php?f=7&t=20097#p153628
add those lines:
Then try again:
sudo apt-get update
This worked perfectly! After doing this I was able to use screen on the ReadyNAS and get PlexConnect running permanently without the need for any computer being on.
Thanks a lot!
I am in the middle of sorting this out, thanks for the advice. Is it possible to have plexconnect on more than on apple TV?
Some more help would be appreciated. I have managed to get the Git installed and python. I have installed PlexConnect and can run it. However when I run cd /etc/frontview/apache  (and then) sudo vi httpd.conf to change 80 i get an error message 'no pattern found'.
I don't know how to resolve this, any help appreciated.
“Is it possible to have plexconnect on more than one apple TV?”
See this thread:
http://forums.plexapp.com/index.php/topic/70211-only-one-atv-connection-at-a-time/
Can anyone release a "NTGR" simple app? I'd be willing to pay/donate.
Me too..
Search Listen with /Listen instead - after that you should have the port of the web server, what do you see there? Probably OS6 is configured differently
Anyone tested v0.1 on Readynas?
Yes, it works
I saw in some other posts that there were better solutions that did not require to change the apache port number, so I worked on applying this to the readynas setup.
The disadvantages of the previous method is that some readynas plugins suchs as "Nas Monitor" could not be launched any more from front view as they relied on the 80 port number, another drawback is by changing the standard httpd.conf file, the modification was overwritten with firmware update (in my case from 4.2.22 to 4.2.23)
After some struggling, I finally succeeded to use the new method (with readynas x86 OS 4). The installation procedure in the header post is updated accordingly
Should be easier now to write a readynas add-on too.
