Trailers us unavailable. Ready NAS Pro-Pioneer, Win 7 64 bit. Help
I have installed and trouble shot per wiki but I can not get it to work.  So here is info:
ATV3 - 6.0.1 - Static IP 192.0.1.42
Certificate created on Win 7 64 bit desktop & installed with iPhone Configuration Utility.  The ".der, .key, .pem" files copied to root of share /media on readynas.
PlexMediaServer (0.9.8.10.215) and Plexconnect (the 2013-10-26.bin version) running on Netgear ReadyNas Pro Pioneer.  Static IP 192.0.1.20.  Running 4.2.24
PMS appears to be running.  I can go to 192.0.1.20:32400 and configure without problem.  Plex runs on iPhone & iPad without problem both locally (wifi) and via cell network.
Plexconnect installed per wiki and ReadyNas thread.  Here is info:
PlexConnect_Virtual.conf
LoadModule proxy_module /usr/lib/apache2/modules/mod_proxy.so
LoadModule proxy_http_module /usr/lib/apache2/modules/mod_proxy_http.so
NameVirtualHost *:80
   SSLEngine off
   ServerName trailers.apple.com
   ServerAlias atv.plexconnect
   ProxyPreserveHost On
   ProxyPass / http://192.0.1.20:81/
   ProxyPassReverse / http://192.0.1.20:81/
NameVirtualHost *:443
    ProxyRequests Off
    SSLEngine on
    SSLProxyEngine On
    SSLProtocol all -SSLv2
    SSLCertificateFile /media/trailers.der
    SSLCertificateKeyFile /media/trailers.key
    Order allow,deny
    Allow from all
    ProxyPass / https://192.0.1.20:444/
    ProxyPassReverse / https://192.0.1.20:444/
    SSLEngine on
    ServerName JSM-NAS
    ServerAlias JSM-NAS
    DocumentRoot /frontview/ui/resource/html
Settings.cfg
[PlexConnect]
enable_webserver_ssl = True
logpath = .
enable_dnsserver = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = False
port_pms = 32400
port_webserver = 81
ip_plexconnect = 192.0.1.20
certfile = /media/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = High
ip_pms = 192.0.1.20
enable_plexgdm = False
port_ssl = 444
Here is the last Log file using these files:
22:58:42 PlexConnect: started: 22:58:42
22:58:42 Settings: getsetting enable_plexconnect_autodetect=False
22:58:42 Settings: getsetting ip_plexconnect=192.0.1.20
22:58:42 PlexConnect: IP_self (from settings): 192.0.1.20
22:58:42 Settings: getsetting enable_dnsserver=True
22:58:42 DNSServer: started: 22:58:42
22:58:42 Settings: getsetting port_dnsserver=53
22:58:42 Settings: getsetting ip_dnsmaster=8.8.8.8
22:58:42 Settings: getsetting prevent_atv_update=True
22:58:42 DNSServer: ***
22:58:42 DNSServer: DNSServer: Serving DNS on 192.0.1.20 port 53.
22:58:42 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.0.1.20
22:58:42 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
22:58:42 DNSServer: forward other to higher level DNS: 8.8.8.8
22:58:42 WebServer: started: 22:58:42
22:58:42 Settings: getsetting port_webserver=81
22:58:42 WebServer: ***
22:58:42 WebServer: WebServer: Serving HTTP on 192.0.1.20 port 81.
22:58:42 ATVSettings: init class CATVSettings
22:58:42 ATVSettings: load settings
22:58:42 Settings: getsetting enable_plexgdm=False
22:58:42 Settings: getsetting ip_pms=192.0.1.20
22:58:42 Settings: getsetting port_pms=32400
22:58:42 XMLConverter: PlexGDM off - PMS from settings: 192.0.1.20:32400
22:58:42 ATVSettings: setOption: update pms_uuid to ('PMS_from_Settings',)
22:58:43 Settings: getsetting enable_webserver_ssl=True
22:58:43 WebServer: started: 22:58:43
22:58:43 Settings: getsetting port_ssl=444
22:58:43 Settings: getsetting certfile=/media/trailers.pem
22:58:43 WebServer: ***
22:58:43 WebServer: WebServer: Serving HTTPS on 192.0.1.20 port 444.
22:59:21 DNSServer: DNS request received!
22:59:21 DNSServer: Source: ('192.0.1.42', 64851)
22:59:21 DNSServer: Domain: itunes-cdn.apple.com.akadns.net
22:59:21 DNSServer: ***forward request
22:59:21 DNSServer: -> DNS response from higher level
22:59:22 DNSServer: DNS request received!
22:59:22 DNSServer: Source: ('192.0.1.42', 58881)
22:59:22 DNSServer: Domain: appleglobal.102.112.2o7.net
22:59:22 DNSServer: ***forward request
22:59:22 DNSServer: -> DNS response from higher level
22:59:22 DNSServer: Source: ('192.0.1.42', 51239)
22:59:22 DNSServer: Domain: a2.mzstatic.apple.com.akadns.net
22:59:22 DNSServer: Source: ('192.0.1.42', 59144)
22:59:22 DNSServer: Domain: a5.mzstatic.apple.com.akadns.net
22:59:22 DNSServer: Source: ('192.0.1.42', 50763)
22:59:22 DNSServer: Domain: a3.mzstatic.apple.com.akadns.net
22:59:22 DNSServer: Source: ('192.0.1.42', 62541)
22:59:22 DNSServer: Domain: a4.mzstatic.apple.com.akadns.net
22:59:22 DNSServer: Source: ('192.0.1.42', 63318)
22:59:22 DNSServer: Domain: a1.mzstatic.apple.com.akadns.net
22:59:23 DNSServer: DNS request received!
22:59:23 DNSServer: Source: ('192.0.1.42', 63477)
22:59:23 DNSServer: Domain: p7-buy.itunes.apple.com.akadns.net
22:59:23 DNSServer: ***forward request
22:59:23 DNSServer: -> DNS response from higher level
22:59:39 DNSServer: DNS request received!
22:59:39 DNSServer: Source: ('192.0.1.42', 58336)
22:59:39 DNSServer: Domain: trailers.apple.com
22:59:39 DNSServer: ***intercept request
22:59:39 DNSServer: -> DNS response: 192.0.1.20
23:04:46 DNSServer: DNS request received!
23:04:46 DNSServer: Source: ('192.0.1.42', 65187)
23:04:46 DNSServer: Domain: p7-buy.itunes.apple.com.akadns.net
23:04:46 DNSServer: ***forward request
23:04:46 DNSServer: -> DNS response from higher level
23:11:15 WebServer: http request header:
Host: 192.0.1.20
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:25.0) Gecko/20100101 Firefox/25.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-US,en;q=0.5
Accept-Encoding: gzip, deflate
Cookie: sdmenu_my_menu=0000000000; SESSION-GUID=vuzeuk12e
Authorization: Basic YWRtaW46em9lcGlwZXI=
Max-Forwards: 10
X-Forwarded-For: 192.0.1.10
X-Forwarded-Host: 192.0.1.20
X-Forwarded-Server: trailers.apple.com
Connection: close
23:11:15 WebServer: http request path:
/admin/
23:11:15 Localize: aTVLanguage: en
23:11:15 WebServer: pms address:
23:11:15 WebServer: cleaned path:
/admin/
23:11:15 WebServer: PlexConnect options:
{'aTVLanguage': 'en', 'aTVAddress': '192.0.1.20'}
23:11:15 WebServer: additional arguments:
23:11:33 WebServer: http request header:
Host: 192.0.1.20:444
Connection: keep-alive
23:11:33 WebServer: http request path:
/admin/
23:11:33 Localize: aTVLanguage: en
23:11:33 WebServer: pms address:
23:11:33 WebServer: cleaned path:
/admin/
23:11:33 WebServer: PlexConnect options:
{'aTVLanguage': 'en', 'aTVAddress': '192.0.1.10'}
23:11:33 WebServer: additional arguments:
/favicon.ico
/favicon.ico
23:11:41 WebServer: http request header:
Host: 192.0.1.20
Max-Forwards: 10
Connection: close
23:11:41 WebServer: http request path:
/admin/
23:11:41 Localize: aTVLanguage: en
23:11:41 WebServer: pms address:
23:11:41 WebServer: cleaned path:
/admin/
23:11:41 WebServer: PlexConnect options:
23:11:41 WebServer: additional arguments:
Here is what I get with - ps -ef | grep "PlexConnect" | grep -v grep
4 lines instead of 3
root      3047     1  0 22:58 ?        00:00:00 python /etc/frontview/addons/bin/PLEXCONNECT/PlexConnect/PlexConnect.py
root      3080  3047  0 22:58 ?        00:00:00 python /etc/frontview/addons/bin/PLEXCONNECT/PlexConnect/PlexConnect.py
root      3085  3047  0 22:58 ?        00:00:00 python /etc/frontview/addons/bin/PLEXCONNECT/PlexConnect/PlexConnect.py
root      3086  3047  0 22:58 ?        00:00:00 python /etc/frontview/addons/bin/PLEXCONNECT/PlexConnect/PlexConnect.py
I do not know if DNS work in this current configuration, but it has worked.  I was able to go to youtube to watch & browse.
I can not access frontview with IP or Host Name.
Thank You in advance for your help.  It is appreciated.  Please let me know if more info is needed.
The above was corrected by restoring the ATV & then redoing the certificate files.
Now I can see my library, however when I try to play a movie I get "An error occurred loading this content. Try again later"
Not sure why this is.  I can play my media with Plex on iPad.
I will post all the data later.
4 prozesses is fine: Main, DNSServer, WebServer, WebServer_SSL
In plexconnect settings I had transcode set to direct play.  The file I was testing with was a .mkv (x264 1920 x 1080 16:9 23.976 fps DTS audio) that required transcode.
Set transcode to auto and file now plays.
A .m4v file also played. (x264 1920 x 800 2.4:1 23.976 fps AC-3 audio)
This topic closed.
