As the title says.. when i had the PMS on my mac and i changed the IP on ATV2 (unhacked) etc it was working..
i decided to put my Plex media server and files on readynas.. and accordingly i changed the Ip on atv2 with the ip of the readynas..
but it wont connect.. i am just unfamilliar with how to put the plex connect folder and edit the py file on readynas 516..
is it possible to get plex connect to work on un jailborken atv 2 or 3? if your server is installed on readynas i mean
Are you running the plexconnect python script on the Ready NAS?
Can you post all the information as per the pinned Read Before Posting thread (http://forums.plexapp.com/index.php/topic/69410-read-before-posting/), as this helps people assist you as it contains log files, config settings etc.
yes sorry..
after all the tries and guides i have been reading and following.. i managed to install plexconnect on readynas, but this is what i get when i try to
./PlexConnect.py
23:12:41 PlexConnect: started: 23:12:41
23:12:41 PlexConnect: ***
23:12:41 PlexConnect: PlexConnect
23:12:41 PlexConnect: Press ENTER to shut down.
23:12:41 PlexConnect: IP_self: 192.168.1.100
23:12:41 PlexGDM: ***
23:12:41 PlexGDM: looking up Plex Media Server
23:12:42 PlexGDM: servers discovered: 1
23:12:42 PlexConnect: PMS: 192.168.1.100:32400
23:12:42 DNSServer: started: 23:12:42
23:12:42 DNSServer: Failed to create socket on UDP port 53: [Errno 98] Address already in use
23:12:42 PlexConnect: DNSServer not alive. Shutting down.
I take it that your Readynas runs its own DNS server
Either you need to disable this (If its possible) or you need to create your own DNS forwarders for trailers.apple.com and atv.plexconnect.
great, thanks alot for your valuable answer. can you please explain how to do any of these or both.. i dont know how to do any of these?
please
how do i find out if my readynas is running its own dns server?
