Where is the DNS redirect done?
Maybe I'm not understanding the question... but using dnsmasq
Did you update /etc/dnsmasq.d/plexconnect.conf and restart the service?
I thought we would only update this file if the port_webserver was updated within the Settings.cfg file
No, that’s for Apache. You need to update the dnsmasq config, select a host and enter in the plexconnect IP address
No, that's for Apache. You need to update the dnsmasq config, select a host and enter in the plexconnect IP address
I've done both of those as well. Uncommented "conf-dir=/etc/dnsmasq.d" and I've added the IP address of the PlexConnect server to the PlexConnect.conf (dnsmasq):
# Uncomment the host you want to intercept and replace
# x.x.x.x with the ip address of PlexConnect#address=/trailers.apple.com/10.9.1.25# address=/secure.marketwatch.com/x.x.x.x# Use the following to block Apple TV updatesaddress=/mesu.apple.com/127.0.0.1address=/appldnld.apple.com/127.0.0.1address=/appldnld.apple.com.edgesuite.net/127.0.0.1
Anybody with any ideas as to how to fix this issue?
For future generations :) I managed to fix this last night, by adding the IP address of the server instead of 127.0.0.1 like so:
ProxyPass / http://10.9.1.25:8080/ nocanon
ProxyPassReverse / http://10.9.1.25:8080/
Plexconnect 0.5 is out.
Major improvements:
- Revamped Audio/Music handling (for iOS>=7.0. That version got a new XML audio player... thanks Beats!)
- GUI improvements: Fanart, Backgrounds... (needs PIL/Pillow library for Python)
- Playlists support (video/audio): continuous play, shuffle, also for TVShow/Season/Episodes
- Save ATVSettings.cfg after changes
Perhaps it would be possible to get an updated rpm? That would be awesome.
Updated to commit 34d2290.
Thank you. I rebuild and now the update feature works (I got a "failed" message before).
Another thing I'm wondering:
BrowserMatch "^(iTunes-)?AppleTV" appletv .. CustomLog logs Order deny,allow Deny from all Allow from env=appletv
Perhaps something like this would be possible:
SetEnvIf Remote_Addr ^192\.168 good_ip=1 # match with local network address SetEnvIf good_ip 0 !appletv # invert appletv env if good_ip is 0
Or something like:
Require env appletv Require ip 192.168.2
I don't know Apache well....
BrowserMatch "^(iTunes-)?AppleTV" appletv .. CustomLog logs Order deny,allow Deny from all Allow from env=appletvWhat would happen, if I open Apache to the world wide web? Could someone with a faked User-agent gain access to the Plex video library?
No, they wouldn't gain access to your video library.
Ok, so the video requests don't go through Apache as a proxy? Plexmediaserver will see it as a remote access? Or will plexconnect not be accessible already.
Hi tkimball83!
Thanks for your job, but can you please help me to create a certificates for Cent OS?
Only /etc/pki/plexconnect/trailers.cer from package work well for me.
marketwatch.cer does not work because domain name changed to video-api-secure.wsj.com
But I need to create certificate for www.icloud.com (WSJ Video) on Cent OS.
I tried this way:
openssl req -new -nodes -newkey rsa:2048 -out ~/icloud.pem -keyout ~/icloud.key -x509 -days 7300 -subj “/C=US/CN=www.icloud.com”
openssl x509 -in ~/icloud.pem -outform der -out ~/icloud.cer && cat ~/icloud.key >> ~/icloud.pem
Please help!!!
P.S. Should I create certificates for Cent OS on Mac or Cent OS? If on Mac should I blame Yosemite OS?
Oh ■■■■… I’m an idiot. Inside emacs /etc/httpd/conf.d/plexconnect.conf
there are paths to SSL cert and key as well.
Need to update it also… Spent 2 days on it…
Are you still having issues? I can generate some more certificates if it helps
No, thanks a lot tkimball83, my certs was correct. My mistake that I didn’t update apache configuration with new cer & key. Thank you for Cent OS build once again.
