Just bought an apple tv 3 also to use netflix but also for plex. I have plex running on a windows 7 desktop computer but cannot for the life of me get them to work. I followed all the instructions on github and as soon as i changed the dns on my apple tv it did not work. I couldn't access any of the other features on the apple tv and i couldn't install the certificate wirelessly.
You will need to provide a lot more information. Logs, settings.cfg etc. Have a read of the pinned “read before posting” thread specifically the troubleshooting/how to report a problem section and provide all the info in the template so we can help you.
instead of bumping the post, actually read the link you have been referred to 3 times now and post ALL of the information it requests - then someone might be able to help.
I don't understand thats why i am asking for support.
I have completed all the steps provided except giving it a static ip.
plex connect is installed on windows 7 latest version (0.3.1+ i think)
plex media is also on windows 7 version 0.9.9.10
plex server version is 0.9.9.10
local ip is 192.168.1.136
download plex connect yesterday from github
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = Normal
logpath = .
I don't know what the problem is. It doesn't seem to run right. As soon as i change the dns on my apple tv then i cant install the certificate or access any other content on my apple tv.
Don't understand the next bullet point.
Ensure you post your 'PlexConnect.log' file to pastebin and post the link ('PlexConnect.log' is located in your PlexConnect folder). If possible, follow these steps to create a "more detailed fresh" one:
shutdown PlexConnect
in 'Settings.cfg', set loglevel to "High"
delete the existing log file
restart PlexConnect
repeat the issue
immediately close PlexConnect and post the log.
in 'Settings.cfg', set the loglevel back to "Normal"
restart PlexConnect
repeat the issue
In the directory you installed PlexConnect into there are 2 files, Settings.cfg and PlexConnect.log - follow those bullet points, and upload your PlexConnect.log file to a forum post.
Right tried it all again as soon as i change the dns on my apple tv then everything goes wrong. I can't access netflix and can't push the certificate to the apple tv.
I changed my computer to a static ip and rebooted my machine, router and apple tv. Like previously stated the problem occurs when i change the dns of the apple tv to the ip_self. When that happens i get no internet connection and can't access anything. When you reboot the apple tv all i get is the setting option and the computers button. Hope this shreds more light on the situation as i am out of ideas now.
