Plexconnect running on any jailbroken iOS device
@wahlman.j said:
try this:
apt-get install wget
Screen Shot on 2015-11-05 at 01:03:23.png - Droplr <— good?
Yes try this again:
apt-get -y update; apt-get -y upgrade; apt-get -y install git; rm -R /Applications/iosjailbreak; cd /Applications; git clone git://github.com/wahlmanj/iosjailbreak.git; cd /Applications/iosjailbreak; ./installios.bash
@wahlman.j said:
Yes try this again:
iPhone image on 2015-11-05 at 01:15:35.jpeg - Droplr <— THAT WORKED!! Thank you very much my friend!
Enjoy :slight_smile: strange wget didn’t install. At least the modified PlexConnect.py is still not needed thanks for confirming that, again. Don’t forget you can use this on multiple aTV’s now that you iOS device is a host. You can also travel with it as well :wink:
Hi there, first of all thanks for this awesome port to iOS.
My issue is that the plexconnect service stops immediately after startup. It works when I manually start PlexConnect.py.
Maxls-5er:/Applications/iosjailbreak root# restart.bash
657 0 com.plex.plexconnect.bash
*** File - /Applications/PlexConnect/PlexConnect.log contents ***
11:48:40 PlexConnect: started: 11:48:40
11:48:40 PlexConnect: Version: 0.5-dev-101215
11:48:40 PlexConnect: Python: 2.7.3 (default, Aug 11 2012, 10:54:38)
[GCC 4.2.1 Compatible Apple Clang 3.0 (tags/Apple/clang-211.11)]
11:48:40 PlexConnect: Host OS: darwin
11:48:40 PlexConnect: PILBackgrounds: Is PIL installed? False
11:48:40 PlexConnect: IP_self: 10.176.57.175
11:48:40 DNSServer: started: 11:48:40
11:48:40 DNSServer: ***
11:48:40 DNSServer: DNSServer: Serving DNS on 10.176.57.175 port 53.
11:48:40 WebServer: started: 11:48:40
11:48:40 WebServer: ***
11:48:40 WebServer: WebServer: Serving HTTP on 10.176.57.175 port 80.
11:48:40 WebServer: WebServer: Serving HTTPS on 10.176.57.175 port 443.
11:58:04 PlexConnect: Shutting down.
11:58:04 DNSServer: Shutting down.
11:58:04 WebServer: Shutting down (HTTPS).
11:58:04 WebServer: Shutting down (HTTP).
11:58:04 PlexConnect: shutdown
Any ideas? I on iOS 8.4 on an iPhone 5.
wrong thread - deleted. :smiley:
Reboot the iOS device and/or try this:
stop.bash
Then:
start.bash
@wahlman.j i have everyhitng installed correctly but i am getting this error about there being no log --> http://d.pr/i/11PKa ? i cant get my certificate uploaded on my apple tv error (-1004) --> http://d.pr/i/1cwNm im assuming it has something to do with the log error? on that note i can confirm that i do not see the log file in the directory? --> http://d.pr/i/15xxA, any idea how to fx this mate?
What iOS/device? Reset the device then try again…
@wahlman.j
sorry about the late reply i forgot to post back about the last issue
so the only way i was able to get this to work was to restore my ios device,
on another note im having another issue , nothing will play as you can see here plex connect installed everything loads fine but when i hit play it stays black the buffer bar loads but that it?
this is whats happening – > https://www.youtube.com/watch?v=Yu9xCQ1KbD4
i dont want to lose my jailbreak by restoring! how do I completely uninstall plex connect from my device mate? that way i could uninstall then reinstall all components and see if that fixes this?
or is there anything else i can do to fix this?
Another option is cydia eraser which will preserve your jailbreak:
https://cydia.saurik.com/package/com.saurik.impactor/
Not sure what is going on with it staying on a black screen, can you post a log from the iOS device? Likely you will need a sftp client to grab the log and post it here from your OS (Cyberduck, Filezilla etc).
Cydia Eraser · Cydia
Not a problem using sftp Where is the log located mate?
Also just for my info worse case scenario is there no way compleatly uninstall plex connect and reinstall?
@wahlman.j
just a quick fyi i setup a completely separate iOS device brand new never had plex connect on it before and it is doing the same thing will not stream will just load the buffer and stay on that screen indefinitely what could cause this mate?
