Plexconnect setup "Trailers not available right now"
what steps u have taken so far?
I have taken all steps for a thousand times! I just don't get it. Here is my log:
09:57:04 PlexConnect: ***
09:57:04 PlexConnect: PlexConnect
09:57:04 PlexConnect: Press CTRL-C to shut down.
09:57:04 PlexConnect: started: 09:57:04
09:57:04 PlexConnect: IP_self: 10.0.1.9
09:57:04 DNSServer: started: 09:57:04
09:57:04 DNSServer: ***
09:57:04 DNSServer: Starting up.
09:57:04 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 10.0.1.9
09:57:04 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
09:57:04 DNSServer: forward other to higher level DNS: 8.8.8.8
09:57:04 WebServer: started: 09:57:04
09:57:04 WebServer: ***
09:57:04 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
09:57:04 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
09:57:04 PlexGDM: ***
09:57:04 PlexGDM: looking up Plex Media Server
09:57:05 PlexGDM: servers discovered: 1
09:57:05 XMLConverter: PlexGDM - PMS: 10.0.1.9:32400
Are you using OSX 10.6.8 ? If so please update your python version to the latest 2.7.5.
Thanks, did that. Log has changed, but I still get "Trailers not available". Current log:
12:06:03 PlexConnect: ***
12:06:03 PlexConnect: PlexConnect
12:06:03 PlexConnect: Press CTRL-C to shut down.
12:06:03 PlexConnect: started: 12:06:03
12:06:07 PlexConnect: IP_self: 10.0.1.2
12:06:07 DNSServer: started: 12:06:07
12:06:07 DNSServer: ***
12:06:07 DNSServer: Starting up.
12:06:07 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 10.0.1.2
12:06:07 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
12:06:07 DNSServer: forward other to higher level DNS: 8.8.8.8
12:06:08 WebServer: started: 12:06:08
12:06:08 WebServer: ***
12:06:08 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
12:06:08 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
12:06:08 PlexGDM: ***
12:06:08 PlexGDM: looking up Plex Media Server
12:06:09 PlexGDM: servers discovered: 1
12:06:09 XMLConverter: PlexGDM - PMS: 10.0.1.2:32400
12:06:10 DNSServer: DNS request received!
12:06:10 DNSServer: Source: ('10.0.1.3', 65451)
12:06:10 DNSServer: Domain: mesu.apple.com
12:06:10 DNSServer: ***restrain request
12:06:10 DNSServer: -> DNS response: 10.0.1.2
12:06:33 DNSServer: DNS request received!
12:06:33 DNSServer: Source: ('10.0.1.3', 57658)
12:06:33 DNSServer: Domain: trailers.apple.com
12:06:33 DNSServer: ***intercept request
12:06:33 DNSServer: -> DNS response: 10.0.1.2
12:06:33 WebServer: serving application.js
12:06:38 DNSServer: DNS request received!
12:06:38 DNSServer: Source: ('10.0.1.3', 53241)
12:06:38 DNSServer: Domain: e5153.b.akamaiedge.net
12:06:38 DNSServer: ***forward request
12:06:38 DNSServer: -> DNS response from higher level
certificate on aTV?
certificate on aTV?
Yes, as I stated in my first post, I followed all the steps on http://langui.sh/201...sl-plexconnect/. The certificate is installed in the aTV. Might help others though, so thanks! Suggestions welcome!
What does your settings.cfg contents look like?
[PlexConnect]
logpath = .
enable_dnsserver = True
ip_webserver = 0.0.0.0
prevent_atv_update = True
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = /Applications/Film/PlexConnect/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
ip_pms = 192.168.178.10
enable_plexgdm = True
port_ssl = 443
[PlexConnect]
logpath = .
port_pms = 32400
port_webserver = 80
loglevel = Normal
port_ssl = 443
You changed location of trailers.pem ? I mean we all have it in plexconnect/assets/certificates and settings.cfg had originally path to that location. Which is ./assets/certificates/trailers.pem
If someone can find another thing wrong with it then fine otherwise would recommend move trailers.pem into that location and have your settings.cfg change to reflect that path. Try it and see maybe it will solve the issue.
Your path is not an absolute path. Try the absolute path:
Users/yourusername/Applications/Film/PlexConnect/assets/certificates/trailers.pem
Change yourusername as appropriate
Edit. Just noticed you have no assets folder listed, if so edit appropriately.
Changed it back to the original location, the path was correct though. Now I've moved everything back to default. Might be a piece, but the problem persists...
Your path is not an absolute path. Try the absolute path: Users/yourusername/Applications/Film/PlexConnect/assets/certificates/trailers.pem Change yourusername as appropriate Edit. Just noticed you have no assets folder listed, if so edit appropriately.
Thanks! Changed it to the absolute path, I made things worse in a way here? Check out the log, gives an error now:
13:50:28 PlexConnect: ***
13:50:28 PlexConnect: PlexConnect
13:50:28 PlexConnect: Press CTRL-C to shut down.
13:50:28 PlexConnect: started: 13:50:28
13:50:28 PlexConnect: IP_self: 10.0.1.2
13:50:28 DNSServer: started: 13:50:28
13:50:28 DNSServer: Failed to create socket on UDP port 53: [Errno 48] Address already in use
13:50:28 PlexConnect: DNSServer not alive. Shutting down.
13:50:28 PlexConnect: Shutting down.
13:50:28 PlexConnect: shutdown
Willems-iMac:~ wsweijland$
No, the problem here is that your previous Plexconnect session did not shutdown properly. Go into Activity Monitor and quit all Python processes and then restart Plexconnect.
Did that already but it didn't work. Rebooting did the trick, but the problem still persists... Really trying to wonder if this will get solved. You guys are a great help though! Log now shows:
15:15:25 PlexConnect: ***
15:15:25 PlexConnect: PlexConnect
15:15:25 PlexConnect: Press CTRL-C to shut down.
15:15:25 PlexConnect: started: 15:15:25
15:15:25 PlexConnect: IP_self: 10.0.1.2
15:15:25 DNSServer: started: 15:15:25
15:15:25 DNSServer: ***
15:15:25 DNSServer: Starting up.
15:15:25 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 10.0.1.2
15:15:25 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
15:15:25 DNSServer: forward other to higher level DNS: 8.8.8.8
15:15:25 WebServer: started: 15:15:25
15:15:25 WebServer: ***
15:15:25 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
15:15:25 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
15:15:25 PlexGDM: ***
15:15:25 PlexGDM: looking up Plex Media Server
15:15:26 PlexGDM: servers discovered: 1
15:15:26 XMLConverter: PlexGDM - PMS: 10.0.1.2:32400
15:23:04 DNSServer: DNS request received!
15:23:04 DNSServer: Source: ('10.0.1.3', 60895)
15:23:04 DNSServer: Domain: ax.init.itunes.apple.com
15:23:04 DNSServer: ***forward request
15:23:04 DNSServer: -> DNS response from higher level
15:23:04 DNSServer: Source: ('10.0.1.3', 55686)
15:23:04 DNSServer: Domain: s.mzstatic.com
15:23:04 DNSServer: Source: ('10.0.1.3', 49570)
15:23:04 DNSServer: Domain: itunes.apple.com
Still looks to me like a path issue.
No other explanation IMO. Something broken with path or Certificate file.
I am facing the same issue since Apple Added the new channels couple of days ago.  I have done everything in this post but i am still having the same issue same as
<span><a class="" href="http://forums.plexapp.com/index.php/user/99364-wsweijland/" title="">wsweijland</a></span>
When on Baa`s github page on right hand side , you can either download as zip or clone to desktop. You can click on clone to desktop and it will ask you to download needed app which you can download from app store. Then after that go back to Baa s page and clone to desktop , it will copy that folder using app to your comp (just to start over, delete older folders and zips). And in future it will keep in sync with whatever new they add. have app running or run everyday and sync the commits.
Now after u get the folder. create a certificates folder in assets folder. and copy your certificate that you created earlier there.  Also just see in your settings.cfg these two lines are present -> port_ssl = 443 ; certfile = ./assets/certificates/trailers.pem
and also make sure when copying certificate, copy trailers.pem file into certificates folder which you created in assets folder.
Hi, I'm sorry but I didn't get it. Where and how do I create my certificate?
I am not so good at these things. Could you please walk me through step by step?
I already downloaded "Plexconnect-master" fromm Baa's website. The link https://github.com/iBaa/PlexConnect/archive/master.zip
And I created the a certificates folder in assests folder. What's next?
My plexconnect screen is also attached.
Please help!
Thanks a lot in advance.
Go here and follow the steps.
http://langui.sh/2013/08/27/appletv-ssl-plexconnect/
I did. Nothing happened.
I use windows 8. I think this guide is for mac or iphone.
Two things:
1. What do you get when you try to connect to https://10.0.1.2/
Do you get an untrusted cert and "not serving host" message, or does it just never connect?  Former, your cert is being found correctly on your server. Latter, it is not.
2. In your logfile, do you see DNS intercept of trailers.apple.com, and see the webserver serving application.js, like below?
12:00:23 DNSServer: Source: ('192.168.0.121', 49764)
12:00:23 DNSServer: Domain: trailers.apple.com
12:00:23 DNSServer: ***intercept request
12:00:23 DNSServer: -> DNS response: 192.168.0.10
12:00:23 WebServer: serving application.js
I have the exact same issue. I can't get trailers to work even though I followed the tutorial thoroughly. Downloaded the latest plexconnect and installed the profile on ATV.
Can anyone with a working installation try two things:
On the machine running the plexconnect. Open a browser and enter the machines ip address with port 80 and with port 443 and post the results here.
In my case it would be 192.168.178.21:80.
Error response
Error code 403.
Message: Not Serving Client 192.168.178.21.
Error code explanation: 403 = Request forbidden -- authorization will not help.
But when I enter [https://192.168.178.21:443](https://192.168.178.21) I get failed to open page. I suspect that my plexconnect installation does't respond to https requests. Can anyone confirm this?
Edit:
I got it finally to work. The path to the trailers.pem have to be absolute. I tried it before but somehow it didn't work. Quick check if the path is right or not:
Enter the address of your plexconnect server in your browser with https:// and 443 as port. If you get a box asking for certificate your plexconnect installation is working properly. If not it can't find the pem file. Check the path to your trailers.pem file in the Settings.cfg.
