I have tried multiple times to run PlexConnect.py from a windows 7 pc.Always stops at
" WebServer: Serving HTTPS on 192.168.0.150 port 443.
WebServer: *** "
Log File:
WebServer: *** "
Log File:
It's not stopping there... well, maybe it kind of is.
But really, it is just waiting for you to get on your couch and start using your aTV/TV.
Really? What a bummer! I shall try that now! It gona make me feel so stupid if that works haha.
@baa
1)I am unable to view any subtitles for any movies.
2) Settings arent saved if the apple tv is restarted.
any help with these?
Subtitles: more info needed - container, codec, subtitle external/internal?
Settings are saved with a proper PlexConnect shutdown - it has nothing do to with aTV's restart.
Thank you. will do a proper shutdown next time.
As for subs, external .srt files . they are contained in the same folder. i do see the option to turn them on. but it cant be seen on screen.
Hope thats enough info for u
*EDIT*: I enabled opensubtitles.org. It downloaded the subs for the movie. On apple tv, under the subs options i enabled "English". When i play the movie, there are no subs present. However, when i use the web browser on my windows machine, the subs appear.
Any help on this?
Movie - container, codec...?
