"plexmediaserver.service.d" issue in Centos 8
I have Plex installed on Centos 8. I used these instructions:
https://support.plex.tv/articles/200288586-installation/
After uploading videos, I am now trying to move the PMS library per these instructions:
My problem is that when I try to create the “override.conf” file it fails:
[root@localhost test]# systemctl edit plexmediaserver
Failed to create directories for “/etc/systemd/system/plexmediaserver.service.d/override.conf”: Not a directory
I have tried using the “systemctl edit plexmediaserver” and “nano /etc/systemd/system/plexmediaserver.service.d/override.conf” but get the same error.
I have tried reinstalling the OS from scratch several times just to make sure I didn’t mess anything up, but I get the same message each time. Not sure what to do, or what is going on. Any help would be greatly appreciated.
You need to be root to create it.
I’m just now getting Centos 8 installed in VM (I had a huge PEBKAC).
I’ll evaluate Centos 8 ASAP (maybe tonight)
ChuckPa, I slept on it and figured out how what I was doing wrong. I was loading DKMS and ZFS prior to adding Plex. I tried installing Plex before DKMS and ZFS and I was able to edit the override.conf file.
After I finish installing DKMS, ZFS, and ZFS Shares, etc I am able to get Plex up and running with video files added. Everything works, except when I try to finish the process of moving over the PMS. After trying to move it over, I can’t connect to the Plex server via my web browser anymore. I have tried both UMask and Umask.
If I can figure this out, I will gladly post the working version for anyone else. In the end I am trying to:
Install Centos 8
Run ZFS
Run Plex
Run transcodes off of seperate SSD
Run PMS off of another seperate SSD
At this point, the only thing missing is to run the PMS from a seperate SSD, otherwise everything else works. I am attaching the instructions I have right now for reference.Centos 8 ZFS Plex Test Server.txt (5.0 KB)
DKMS (Dynamic Kernel) shouldn’t be an issue unto itself.
I presume those modules are dynamically required for ZFS to run.
I do have a thought on the mount point:
  1. mkdir
  2. chown plex:plex of the mount point itself first
  3. mount the file system
  4. chown plex:plex again of the mounted FS’s root.
A similar thing happens with network shares
If you need more control over when PMS starts, in your customization override.conf,
you can add After= then name the ZFS or DKMS startup service(s).
Making sense?
I think so. I’ll play around with it and see. Thanks!
