what am i filling in the these fields with?
add key=“masterName” value="" />
!-- Owner User ID -->
add key=“masterEmail” value="" />
!-- Owner EMail -->
add key=“masterPassword” value="" />
Thanks!!
!-- Owner EMail -->
Thanks!!
Yep i get a blank screen like a member i’ve just noticed on a previous page
In the dev console i see a database.plex-sqlite.aspx error
Request URL:http://192.168.0.6/database.plex-sqlite.aspx Request Method:POST Status Code:500 Internal Server Error Remote Address:192.168.0.6:80
@smckay79 said:
what am i filling in the these fields with?add key=“masterName” value=“” />
!-- Owner User ID →
add key=“masterEmail” value=“” />
!-- Owner EMail →
add key=“masterPassword” value=“” />Thanks!!
That is your account for Plex. the one you would sign into.
I am not using sqllite so I will be of little help. But that means your database connection string is bad in that file. SQL Explress is what I am using.
@jskala said:
!-- Owner User ID →
!-- Owner EMail →
Thanks what i thought - I keep getting this for an error…
config looks like…
add key=“PlexSentryDB” value=“Data Source=DE5\SQLEXPRESS;Initial Catalog=PlexSentry; Integrated Security=TRUE;” />
!-- SQL connection string →
add key=“masterName” value=“PLEXUSERNAME” />
!-- Owner User ID →
add key=“masterEmail” value=“EMAILADDRESS” />
!-- Owner EMail →
add key=“masterPassword” value=“PLEXPASSWORD” />
!-- Owner Password →
add key=“serverName” value=“192.168.1.180” />
!-- Plex Server Domain Name or IP →
add key=“serverPort” value=“32400” />
Ok, thanks for your help jskala, at least i’ve got an idea where to look now, will go over it and try and spot the error i’ve made.
@smckay79 said:
@jskala said:
!-- Owner User ID →
!-- Owner EMail →
config looks like…
!-- Owner User ID →
!-- Owner EMail →
Might be beyond me but it appears you are not able to login to plex.tv account. or your server isn’t talking back to it for it to get the data etc. Do you have a valid account?
Good luck. the dev options in chrome helped me to find most of my issues.
@jskala said:
@smckay79 said:
@jskala said:
!-- Owner User ID →
!-- Owner EMail →
config looks like…
!-- Owner User ID →
!-- Owner EMail →
add key=“serverPort” value=“32400” />Might be beyond me but it appears you are not able to login to plex.tv account. or your server isn’t talking back to it for it to get the data etc. Do you have a valid account?
Brilliant!!!
This machine runs PIA (Private Internet Access) which I had set to kill the internet if it wasn’t connected, I disconnected it so i could use teamviewer quicker on it! Woot, i’m in!! Sometimes its the little things we all miss!
-S
@smckay79 said:
@jskala said:
@smckay79 said:
@jskala said:
!-- Owner User ID →
!-- Owner EMail →
config looks like…
!-- Owner User ID →
!-- Owner EMail →
Brilliant!!!
-S
Glad you got it working.
Alright, so my last issue is a blank website, Debug mode shows nothing outstanding,
My connection string in the database.plex.aspx file is
> sqlConnection.ConnectionString = ConfigurationManager.ConnectionStrings["Data Source=COMPUTERNAME\SQLEXPRESS;Initial Catalog=PlexSentry; Integrated Security=TRUE;"].ConnectionString;
Any Ideas?
@smckay79 said:
Alright, so my last issue is a blank website, Debug mode shows nothing outstanding,My connection string in the database.plex.aspx file is
> sqlConnection.ConnectionString = ConfigurationManager.ConnectionStrings["Data Source=COMPUTERNAME\SQLEXPRESS;Initial Catalog=PlexSentry; Integrated Security=TRUE;"].ConnectionString;Any Ideas?
In the chrome debug the network tab shows nothing on a refresh in red?
Here is my entry
sqlConnection.ConnectionString = "Data Source=COMPUTERNAME\\SQLEXPRESS;Initial Catalog=PlexSentry;Persist Security Info=True;User ID=sa;Password=PASSWORD";
I have the SA user enabled on my setup not sure what you did. But this works for me.
Nothing in red…
https://www.evernote.com/l/AAFyazC7RdZBKqJV9RtxCv2hHvZjBc0swQo
@smckay79 said:
Nothing in red…
One thing I noticed is I don’t see it hitting databse.plex.aspx. When mine is running it hits that.
What does your plexsentry.exe window look like as it is running?
Im just re-doing the database side of things right now, so i noticed there is an error, but > @jskala said:
@smckay79 said:
Nothing in red…One thing I noticed is I don’t see it hitting databse.plex.aspx. When mine is running it hits that.
im just redoing the database side of things, so there is an error there now, here it a screenshot
so I see activity on the DB, so i know the plexsentry.exe is working…
https://www.evernote.com/l/AAFYskXfnmZCuZ0IhKuH6hG4K0xKJUMMJCQ
hmmmm 2 errors on the console tab
Uncaught SyntaxError: Unexpected token var
index.aspx:22 Uncaught ReferenceError: web_events is not defined
You have anything playing at the time you are looking?
@smckay79 said:
hmmmm 2 errors on the console tabUncaught SyntaxError: Unexpected token var
token var is interesting you haven’t filled in a token value in any of the files have you?.
@jskala said:
@smckay79 said:
so I see activity on the DB, so i know the plexsentry.exe is working…You have anything playing at the time you are looking?
@jskala said:
No, nothing playing.
