Hi bulliscory, Are you using a terminal to access your SPC or just your browser? You’ll need to use a terminal shell to do the rest of this tutorial.
Sorry, terminal shell?
Depending on your OS, there is a program that allows you to use the SSH protocol to access your SPC. On MacOS and Linux it’s called the Terminal. On Windows I believe it’s called the Command Prompt (not sure as I only have Mac and Ubuntu machines). You’ll use this program to complete parts 2 and 3 of the tutorial.
