Plugin development and IDE
Do you know if it is possible to setup any IDE which control the syntax and the code consistency to know all the classes, methods and constants used in plugins ?
I'm using sublime text 2 with sublimerope plugin but most of the code is marked with errors.
Do you have solution or advice for simple IDE for plugin development ?
If this is possible I would like to know how as well, although I use Komodo IDE ;)
As an alternative, I have in the past used available online docs for a project to create a mock library so I can view the information within my IDE, I'm sure there is enough information available to do so with Plex? In fact, Using the Framework information provided here would be a good start. Also note that docs are generated automatically so all you need to do is place it into your 'PythonXX/Lib/site-packages' folder and reload your IDE, or (if available) manually refresh the docs in your IDE's settings.
More information regarding optimizing modules for documentation can be found here.
Hope this helps!
