PMS unreachable on Synology NAS after update to 1.22.3.4392 (edit: failed DB upgrade?)
Server Version#: 1.22.3.4392-6000
Player Version#: n/a
Synology Model: DS918+
Updated Plex Media Server to 1.22.3.4392 this morning and now the web portal won’t launch, and the Plex online service thinks the PMS on the NAS is not available. Cannot reach it from Plex for iOS or Apple TV.
The Plex Media Server process is running, but doesn’t appear to be doing anything particularly useful:
$ ps -efj | grep Plex
plex     11925     1 11902 11902  1 19:37 ?        00:00:10 /var/packages/Plex Media Server/target/Plex Media Server
edit: I think the database upgrade failed somehow. See below…
Yeah, I think you’re just replying to gain points / reputation on this forum without diving into the problem…
I think there’s something wrong with the underlying database.
On closer inspection, the logs show some alteration that occurred during upgrade, and it fell on its face.
admin@librarycore:/volume1/Plex/Library/Application Support/Plex Media Server/Logs$ cat "Plex Media Server.1.log"
Apr 24, 2021 19:13:11.603 [0x7f3dee1d9700] INFO - Plex Media Server v1.22.3.4392-d7c624def - Synology DS918+ x86_64 - build: linux-x86_64 synology - GMT -07:00
Apr 24, 2021 19:13:11.603 [0x7f3dee1d9700] INFO - Linux version: DSM 6.2.3.25423-0, language: en-US
Apr 24, 2021 19:13:11.603 [0x7f3dee1d9700] INFO - Processor Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
Apr 24, 2021 19:13:11.603 [0x7f3dee1d9700] INFO - /var/packages/Plex Media Server/target/Plex Media Server
Apr 24, 2021 19:13:11.946 [0x7f3df8a61780] INFO - SQLITE3:(nil), 283, recovered 1385 frames from WAL file /volume1/Plex/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Apr 24, 2021 19:13:18.930 [0x7f3df8a61780] WARN - Held transaction for too long (../Library/DatabaseMigrations.cpp:231): 1.030000 seconds
Apr 24, 2021 19:14:23.908 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.911 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.915 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.918 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.922 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.926 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.930 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.933 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.937 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.941 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.945 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.949 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.953 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.957 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.961 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.966 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.970 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.974 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:23.978 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Apr 24, 2021 19:14:27.775 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 22: [SELECT (SELECT max(idx) FROM 'main'.'fts4_tag_titles_segdir' WHERE level = ?) + 1] database schema has changed
Apr 24, 2021 19:14:27.775 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 20: [SELECT coalesce((SELECT max(blockid) FROM 'main'.'fts4_tag_titles_segments') + 1, 1)] database schema has changed
Apr 24, 2021 19:14:27.775 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 13: [REPLACE INTO 'main'.'fts4_tag_titles_segments'(blockid, block) VALUES(?, ?)] database schema has changed
Apr 24, 2021 19:14:27.779 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 25: [REPLACE INTO 'main'.'fts4_tag_titles_segdir' VALUES(?,?,?,?,?,?)] database schema has changed
Apr 24, 2021 19:14:27.779 [0x7f3df8a61780] INFO - SQLITE3:(nil), 17, statement aborts at 22: [SELECT level, idx, end_block FROM 'main'.'fts4_tag_titles_segdir' WHERE level BETWEEN ? AND ? ORDER BY level DESC, idx ASC] database schema has changed
Apr 24, 2021 19:18:21.268 [0x7f3df8a61780] WARN - Held transaction for too long (../Library/FullTextSearch.cpp:59): 26.440000 seconds
Apr 24, 2021 19:18:56.144 [0x7f3df8a61780] WARN - Held transaction for too long (../Library/FullTextSearch.cpp:69): 5.240000 seconds
Apr 24, 2021 19:19:27.043 [0x7f3df8a61780] WARN - Held transaction for too long (../Library/FullTextSearch.cpp:80): 4.390000 seconds
Apr 24, 2021 19:19:43.312 [0x7f3df8a61780] WARN - Held transaction for too long (../Library/FullTextSearch.cpp:90): 2.540000 seconds
Apr 24, 2021 19:19:43.313 [0x7f3df8a61780] WARN - Held transaction for too long (../Library/DatabaseMigrations.cpp:231): 40.970000 seconds
admin@librarycore:/volume1/Plex/Library/Application Support/Plex Media Server/Logs$ cat "Plex Media Server.log"
Apr 24, 2021 19:37:09.231 [0x7f6834cf1700] INFO - Plex Media Server v1.22.3.4392-d7c624def - Synology DS918+ x86_64 - build: linux-x86_64 synology - GMT -07:00
Apr 24, 2021 19:37:09.231 [0x7f6834cf1700] INFO - Linux version: DSM 6.2.3.25423-0, language: en-US
Apr 24, 2021 19:37:09.231 [0x7f6834cf1700] INFO - Processor Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
Apr 24, 2021 19:37:09.231 [0x7f6834cf1700] INFO - /var/packages/Plex Media Server/target/Plex Media Server
Apr 24, 2021 19:37:09.374 [0x7f683f579780] INFO - SQLITE3:(nil), 283, recovered 11 frames from WAL file /volume1/Plex/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Apr 24, 2021 19:37:10.303 [0x7f683f579780] INFO - SQLITE3:(nil), 283, recovered 377 frames from WAL file /volume1/Plex/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db-wal
Apr 24, 2021 19:37:10.800 [0x7f683f579780] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
My NAS has never reported any disk errors, and there is more than 50GB free on volume1 right now.
May we please have DEBUG (not INFO or VERBOSE) log files ZIP;
  1. Change log settings - SAVE changes
  2. Restart PMS
  3. Let start for 60 seconds
  4. Attempt to connect
  5. Stop Plex
  6. Manually create a ZIP file of the Logs directory in the Plex share.
  7. Attach said ZIP file here.
Service wasn’t even starting to the point where I could change the log settings.
Letting Plex regenerate the Preferences file allowed Plex to relaunch and sign in, but it still says the library is “unavailable.”
Be advised,
When it comes to log files, plus several other settings, we don’t need the GUI.
We can effect settings changes via the Synology Text Editor and the Preferences.xml file.
In the case of logging. the addtion of logDebug="1" inside the XML structure is all it takes to enable DEBUG logging.
Hello,
same problem here:
Server: 1.22.3.4392-6000
Synology 1621+
The steps from [trumpy81] doesn´t help.
-Heimo
Hello,
same problem. Please find attached the log files.
Log files
-Heimo
Here is the debug log. This is the first ~20 minutes from the most recent startup, without media scan activity.
In the local Plex console, I am seeing orange exclamation marks next to every library (movies, tv, music).
PS: I don’t think it’s a good idea to upload the entire log folder to a publicly accessible forum, since it includes media scan activity and potentially every title in your library.
@fuchshei_chello_at
I attempted to retrieve the logs. Nothing was available at that URL
Link is back … sorry
So far my problem is solved. My pihole DNS filter has blocked a domain …
Thank you,
Heimo
Hey @fuchshei_chello_at , can you please share the domain(s) that were blocked? I’m also using a PiHole but there was no issue until the recent upgrade. Maybe Plex added something new.
hxxp://r3.o.lencr.org … seems to be a domain from lets encrypt
-Heimo
I just checked my DNS filter configuration and it looks like the PiHole isn’t serving DNS queries to the NAS. So that’s ruled out. The NAS is using my router’s default DNS lookup, which just goes upstream to the ISP, and I can resolve the same domain on other machines on my network.
What else could it be?
Well the end of this saga is that there were duplicate entries for my NAS in the Library section. Three in total. Two were offline. When I deleted the second one, my ‘pinned’ sources disappeared. I think my library is still there. Currently checking…
@fuchshei_chello_at @ChuckPa @trumpy81 :
This is resolved. Thank you.
Have there been other reports of this happening to Plex Media Server users updating to this version, or is it random and unpredictable during routine upgrades?
