Got it! Will do-- annoyingly I JUST fresh-installed 22.04 a few weeks ago due to a totally unrelated problem. Guess I will do it again
Extra Practice makes Extra Perfect
ps: Iām waiting on 26.04, or even 28.04 before moving from 22.04
Oh you know one thing I just thought of though I donāt know if ti makes a difference.
My /var/lib/plexmediaserver symlinks into /mnt/plexdata because I put it on a SSD. Do you think that could cause an issue?
Holy hell..
Thatās important.
Stop the presses!!!
Iām willing to bet you donāt have /mnt/plexdata nounted with exec privilege. ???
Time to fix this the right way.
- With PMS stopped
- Remove the symlink
- Recreate /var/lib/plexmediaserver and set owner
plex:plex
( Required to have a real $HOME directory ) - Create:
ā /etc/systemd/system/plexmediaserver.service.d/override.conf - Contents:
[Service]
Environment="PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/mnt/plexdata/Library/Application Support"
- EDIT the /etc/fstab line for
/mnt/plexdata. ADD,execoption
Confirm the path above. Adjust as appropriate.
Ref:
I did all that but alas, same error upon reboot.
grab one last set of logs from āLogsā. Letās see if any change.
What Iām reading is AppArmour being hostile. Iāve never seen it this way before.
There are a lot of folks using 24.04.
This is what I donāt understand.
When you reinstall 22.04, Install the DEFAULT (Minimal) Gnome desktop with the new /partition scheme (āsomething elseā option)
Logs.tar.gz (117.7 KB)
For funsies I tried to disable app armor via GRUB_CMDLINE_LINUX="apparmor=0" and a reboot, still doesnt work
itās too interwoven into the whole thing. You canāt disable it.
Womp. Well I am standing by to do your instructions if those Logs come back with nothing helpful either.
what are all those containers youāre running.
What Iām finding now:
Start: 17:47:27.534
Aborted: 17:47:30.264
PMS has signal traps built in. This termination is so hostile, it canāt even exit cleanly.
Itās time
Off we go! Appreciate the help none the less, I guess better it happens now before I get more stuff set up and have to redo moreā¦
Hours wasted but im back up on 22.04!
All good and running?
Did you create /home partition?
Put APP SUPP Dir in /home/plex ?
For laughs, this is my PMS.
[chuck@lizum ~.2001]$ cat /etc/systemd/system/plexmediaserver.service.d/override.conf
[Service]
Environment="PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/usb/plex"
User=chuck
Group=chuck
[chuck@lizum ~.2002]$
/usb is a NVMe SSD on USB3 type C ![]()
Looks like this:
[chuck@lizum ~.2004]$ df -h
Filesystem Size Used Avail Use% Mounted on
efivarfs 192K 116K 72K 63% /sys/firmware/efi/efivars
/dev/nvme0n1p2 122G 33G 90G 27% /
/dev/nvme0n1p4 1.0T 363G 661G 36% /home
/dev/nvme0n1p1 499M 65M 434M 13% /boot/efi
/dev/nvme2n1p1 931G 144G 788G 16% /sata
/dev/nvme2n1p2 932G 251G 681G 27% /usb
Incus/containers/plexdev 915G 1.1G 914G 1% /var/lib/incus/storage-pools/Incus/containers/plexdev
Incus/containers/rocky9 915G 602M 914G 1% /var/lib/incus/storage-pools/Incus/containers/rocky9
Incus/containers/wirepod 915G 978M 914G 1% /var/lib/incus/storage-pools/Incus/containers/wirepod
[chuck@lizum ~.2005]$ sudo dd if=/dev/nvme2n1 iflag=direct of=/dev/null bs=4M count=5000
5000+0 records in
5000+0 records out
20971520000 bytes (21 GB, 20 GiB) copied, 4.30683 s, 4.9 GB/s
[chuck@lizum ~.2006]$
I am back in up and running yep!
Also I am 99% sure I figure out the issue, when I installed my Nvidia graphics driver, things stopped working again, downgraded and works fine. So I suspect 24.04 would have the same issue If I was brave enough to try and upgrade again, which im not.
Oh? Which Nvidia driver did you install?
`nvidia-driver-570ā from apt is what I installed originally, I believe
Ahh, that explains it.
I have the RTX 2000 ada gen. Iām running the 565 drivers. (565.77)
With the P2200 , I run the 550 drivers. (550.120)
I would consider backing down off the 570 ledge. Itās new & somewhat Bleeding Edge.
Yeah I think I just picked it because it was new⦠too bad I didnt figure that out before I reinstalled 22.04, oh well. You live and you learn.
