Yesterday I updated my Ubuntu Server to 16.04.1 then I updated my Plex updated to 1.0.3.2461
Then my problems started. Plex stopped working as the Plex install failed. I tried uninstalling it, re-installing, still the same Plex failed to install. Below are what the reports say.
(Reading database ... 135911 files and directories currently installed.)
Preparing to unpack .../plexmediaserver_1.0.3.2461-35f0caa_amd64.deb ...
Removed symlink /etc/systemd/system/multi-user.target.wants/plexmediaserver.service.
Unpacking plexmediaserver (1.0.3.2461-35f0caa) over (1.0.3.2461-35f0caa) ...
Setting up plexmediaserver (1.0.3.2461-35f0caa) ...
OK
Job for plexmediaserver.service failed because the control process exited with error code. See "systemctl status plexmediaserver.service" and "journalctl -xe" for details.
dpkg: error processing package plexmediaserver (--install):
subprocess installed post-installation script returned error exit status 1
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for systemd (229-4ubuntu7) ...
Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu5) ...
Processing triggers for mime-support (3.59ubuntu1) ...
Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160701-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
systemctl reads
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: inactive (dead) (Result: exit-code) since Sun 2016-07-31 09:47:49 BST; 1min 16s ago
Process: 11186 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, status=216/GROUP)
Jul 31 09:47:44 Andy-server systemd[1]: Starting Plex Media Server for Linux...
Jul 31 09:47:44 Andy-server systemd[1]: plexmediaserver.service: Control process exited, code=exited status=216
Jul 31 09:47:44 Andy-server systemd[1]: Failed to start Plex Media Server for Linux.
Jul 31 09:47:44 Andy-server systemd[1]: plexmediaserver.service: Unit entered failed state.
Jul 31 09:47:44 Andy-server systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
Jul 31 09:47:49 Andy-server systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
Jul 31 09:47:49 Andy-server systemd[1]: Stopped Plex Media Server for Linux.
Jul 31 09:47:49 Andy-server systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Jul 31 09:47:49 Andy-server systemd[1]: Failed to start Plex Media Server for Linux.
journalctl-xe reads
> -- Unit plexmediaserver.service has finished shutting down.
> Jul 31 09:47:38 Andy-server systemd[11184]: plexmediaserver.service: Failed at step GROUP spawning /bin/sh: No such process
> -- Subject: Process /bin/sh could not be executed
> -- Defined-By: systemd
> -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
> -- The process /bin/sh could not be executed and failed.
> -- The error number returned by this process is 3.
> Jul 31 09:47:38 Andy-server systemd[1]: Starting Plex Media Server for Linux...
> -- Subject: Unit plexmediaserver.service has begun start-up
> -- Unit plexmediaserver.service has begun starting up.
> Jul 31 09:47:38 Andy-server systemd[1]: plexmediaserver.service: Control process exited, code=exited status=216
> Jul 31 09:47:38 Andy-server systemd[1]: Failed to start Plex Media Server for Linux.
> -- Subject: Unit plexmediaserver.service has failed
> -- Unit plexmediaserver.service has failed.
> -- The result is failed.
> Jul 31 09:47:38 Andy-server systemd[1]: plexmediaserver.service: Unit entered failed state.
> Jul 31 09:47:38 Andy-server systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
> Jul 31 09:47:44 Andy-server systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
> Jul 31 09:47:44 Andy-server systemd[1]: Stopped Plex Media Server for Linux.
> -- Subject: Unit plexmediaserver.service has finished shutting down
/lib/systemd/system/plexmediaserver.service reads
[Unit]
Description=Plex Media Server for Linux
After=network.target
[Service]
Environment="PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/var/lib/plexmediaserver/Library/Application Support"
Environment=PLEX_MEDIA_SERVER_HOME=/usr/lib/plexmediaserver
Environment=PLEX_MEDIA_SERVER_MAX_PLUGIN_PROCS=6
Environment=PLEX_MEDIA_SERVER_TMPDIR=/tmp
ExecStartPre=/bin/sh -c '/usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}"'
ExecStart=/bin/sh -c 'LD_LIBRARY_PATH=/usr/lib/plexmediaserver /usr/lib/plexmediaserver/Plex\ Media\ Server'
Type=simple
User=plex
Group=plex
Restart=on-failure
RestartSec=5
StartLimitInterval=60s
StartLimitBurst=3
[Install]
WantedBy=multi-user.target
Hopefully someone can help as it is driving me nuts trying to fix it.
