possible to change poster size?
when in Grid and I am looking at the movie posters in the Grid, I find the posters a little too small.
is there a way to say make the row 6 movie posters across instead of 7 so as to bump the size of the posters up a bit?
Sure, in Movie_Grid.xml just change columnCount="7" to columnCount="6".
However, unfortunately the interface item has a fixed size regardless of how many you display across the screen.
What you could do is replace the and with and , however this causes problems with the titles being displayed to low pushing them underneath the poster below it.
Sure, in Movie_Grid.xml just change columnCount="7" to columnCount="6".However, unfortunately the interface item has a fixed size regardless of how many you display across the screen.
yay and rats... thanks for letting me know about both sides of my request. are you aware of this being an Apple limitation or part of the design of PlexConnect?
We use Apple’s own interface so we have no control of things like size, there is nothing PlexConnect can do about it :frowning:
We use Apple's own interface so we have no control of things like size, there is nothing PlexConnect can do about it :(
I KNEW it couldn't have been your doing. Apple has so much to learn from you guys.
Hi, this is old post so it seems things have changed. I can’t find the movie_grid.xml, is there a new place to change this?
Take a look at PlexConnect/assets/templates and you will find several folders, Movie, TVShow (and probably others) contain a grid.xml file
