Preferences.xml
How to access Preferences.xml on ubuntu.
From https://support.plex.tv/articles/202915258-where-is-the-plex-media-server-data-directory-located/
Linux and Other Devices
General
In general, the location for the various Linux versions of Plex Media Server will be found under:
$PLEX_HOME/Library/Application Support/Plex Media Server/
For a default Ubuntu setup $PLEX_HOME is
/var/lib/plexmediaserver/
So the full path is:
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Preferences.xml
Thanks for replaying back. i have tried that but I’m getting this
bash: /var/lib/plexmediaserver/Library/Application: Permission denied
You’ll need to escape the spaces in that path or put it in quotes to get there, e.g.
cd "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/"
or
cd /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/
The folders belong to the service account plex but should be readable by all users of the system – so I don’t think this is an actual permission problem. If it gives you trouble you should still be able to access it with sufficient privileges (e.g. using an admin account of yours).
