Problem with a new update of docker?
Server Version#:
can’t provide any of these information since the problem is upstream.
since the udpate of docker of yesterday
docker: Error response from daemon: OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: Running hook #1:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: cuda error: unknown error: unknown.
docker-ce-cli/focal,now 5:20.10.10~3-0~ubuntu-focal amd64 [installed,automatic]
docker-ce-rootless-extras/focal,now 5:20.10.10~3-0~ubuntu-focal amd64 [installed,automatic]
docker-ce/focal,now 5:20.10.10~3-0~ubuntu-focal amd64 [installed]
docker-scan-plugin/focal,now 0.9.0~ubuntu-focal amd64 [installed,automatic]
docker/focal,focal,now 1.5-2 all [installed]
nvidia-docker2/now 2.2.2-1 all [installed,local]
python3-docker/focal,focal,now 4.1.0-1 all [installed,automatic]
wmdocker/focal,now 1.5-2 amd64 [installed,automatic]
does the docker run command not work anymore? and should I go through docker compose now?
or is it jsut a bug from docker itself like this one :
thanks in advance for your input
Have you tried rebooting?
I had the same issue as you and found this Unable to start an interactive container with nvidia-docker due to driver/library version mismatch · Issue #1451 · NVIDIA/nvidia-docker · GitHub which showed it wasn’t the Plex container that was the issue
Well the problem here is that the nvidia-smi works as intended as for the libraries
So I m totally willing to look for the specific libraries just to be sure but I m pretty confident this is not the problem
have you tried removing and reinstalling nvidia-docker2 ?
