Problem with EpisodeObject and Video URL
Hi @ all
I'm trying to fix the SFR.tv Plugin, but i'm not able to get the Videos play in Plex :-(
There are two URLs per Item on the WebPage for the same Video:
URL 1 witch is a Standalone Player:
http://www.srf.ch/player/tv/popupvideoplayer?id=abe97246-f3fa-4828-aec0-1f32d50e9f80
URL 2 witch is a empeded Player inside a Webpage:
http://www.srf.ch/player/tv/1-gegen-100/video/schlagfertig-und-bisher-erfolgreich-michael-inderkum-aus-altdorf?id=abe97246-f3fa-4828-aec0-1f32d50e9f80
If i use the URL 2, it results in a "the media server responded with an error" as soon as i like to Create an EpisodeObject.
2014-03-29 18:56:55,504 (11070a000) :  DEBUG (networking:167) - Fetching 'http://www.srf.ch/player/tv/sendung/1-gegen-100?id=6fd27ab0-d10f-450f-aaa9-836f1cac97bd' from the HTTP cache
2014-03-29 18:56:55,563 (11070a000) :  WARNING (runtime:1059) - Generating a callback path for a function with no route:
2014-03-29 18:56:55,567 (11070a000) :  DEBUG (services:602) - No service found for URL 'http://www.srf.ch/player/tv/popupvideoplayer?id=52940171-549c-44bf-94f6-4bdbdb168ebf'
2014-03-29 18:56:55,568 (11070a000) :  DEBUG (services:617) - No matching services found for 'http://www.srf.ch/player/tv/popupvideoplayer?id=52940171-549c-44bf-94f6-4bdbdb168ebf'
2014-03-29 18:56:55,569 (11070a000) :  DEBUG (services:41) - Loading service code for Fallback (URLServiceRecord)
2014-03-29 18:56:56,084 (11070a000) :  DEBUG (services:602) - No service found for URL 'http://www.srf.ch/player/tv/popupvideoplayer?id=52940171-549c-44bf-94f6-4bdbdb168ebf'
2014-03-29 18:56:56,088 (11070a000) :  CRITICAL (runtime:964) - Exception when constructing response (most recent call last):
  File "/Users/busa/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/runtime.py", line 945, in construct_response
    el = result._to_xml()
  File "/Users/busa/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/objectkit.py", line 613, in _to_xml
    el = Framework.modelling.objects.ModelInterfaceObjectContainer._to_xml(self)
  File "/Users/busa/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/modelling/objects.py", line 382, in _to_xml
    root = Container._to_xml(self)
  File "/Users/busa/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/modelling/objects.py", line 139, in _to_xml
    self._append_children(root, self._objects)
  File "/Users/busa/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/modelling/objects.py", line 145, in _append_children
    el = obj._to_xml()
  File "/Users/busa/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/objectkit.py", line 531, in _to_xml
    if self._core.services.function_in_service_is_deferred(Framework.components.services.MEDIA_OBJECTS_FUNCTION_NAME, service):
  File "/Users/busa/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/services.py", line 556, in function_in_service_is_deferred
    service.sandbox.context.import_values(values)
AttributeError: 'NoneType' object has no attribute 'sandbox'
2014-03-29 18:56:56,088 (11070a000) :  DEBUG (runtime:1021) - Unable to handle response type: <class ‘Framework.modelling.objects.MediaContainer’>
2014-03-29 18:56:56,090 (11070a000) :  DEBUG (runtime:918) - Response: [500] MediaContainer, 0 bytes
If i use the  URL 2, i can create the EpisodeObjects and they get listet, but as soon as i try to play an Episode, it results in an "Cannot load M3U8: 404 not found"
Would be great if somebody could help me with that Problem.
Greetings
busa
Sounds like either:
  • there is not an existing URL Service for that website
  • the URL Service which handles that website is in need of updating
