Problem with URL Service
I try to develop a url service to stream rtmp videos.
I already activated real rtmp in my ServiceInfo.plist, but keep getting the following error:
2014-10-27 19:32:17,506 (43a39470) :  DEBUG (context:198) - Checking for Real RTMP support...  Enabled:True  Platform:Plex Home Theater  Product:Plex Home Theater  Client:1.2.2.331-2d6426d7  Server:None
2014-10-27 19:32:17,513 (43a39470) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400'
2014-10-27 19:32:17,538 (43a39470) :  DEBUG (core:522) - Unable to read server attribute 'serverVersion'
2014-10-27 19:32:17,551 (43a39470) :  DEBUG (objectkit:939) - Using WebKit RTMP
2014-10-27 19:32:17,570 (43a39470) :  CRITICAL (sandbox:303) - Exception when calling function 'PlayVideo' (most recent call last):
  File "/volume1/Plex/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/sandbox.py", line 294, in call_named_function
    result = f(*args, **kwargs)
  File "/volume1/Plex/Library/Application Support/Plex Media Server/Plug-ins/Vox Now.bundle/Contents/Services/URL/VoxNow/ServiceCode.pys", line 37, in PlayVideo
    return IndirectResponse(VideoClipObject, key=RTMPVideoURL(url = 'rtmpe://fms-fra12.rtl.de/voxnow/', clip = 'mp4:' + playpath, swf_url = playerUrl, pageUrl = pageurl, app = angebot, swfvfy = True))
  File "/volume1/Plex/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/objectkit.py", line 945, in _rtmp_video_url
    unsupported(swf_url, 'swf_url')
  File "/volume1/Plex/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/objectkit.py", line 943, in unsupported
    raise Framework.exceptions.NonCriticalArgumentException("The '%s' argument is only supported when real RTMP playback is enabled." % name)
NonCriticalArgumentException: (2104, "The 'swf_url' argument is only supported when real RTMP playback is enabled.")
My ServiceInfo.plist
<?xml version="1.0" encoding="UTF-8"?>
		PlexFrameworkFlags
			UseRealRTMP
	<key>URL</key>
	<dict>
		<key>VoxNow</key>
		<dict>
			<key>URLPatterns</key>
			<array>
				<string>http://([^.]+.).voxnow.de/.+</string>
			</array>
			<key>TestURLs</key>
			<array>
				<string>http%3A%2F%2Fwww.voxnow.de%2F2-profis-fuer-4-raeder%2Fein-oldtimer-aus-frankreich.php%3Fcontainer_id%3D183253%26player%3D1%26season%3D1</string>
			</array>
		</dict>
	</dict>
</dict>
Is someone able to help?
Thank you very much!
Just a short information:
Even the official channel "The Hollywood Reporter" is not working. I get the same error as above.
Ok, this seems to be a problem with the Windows Client on Windows 8.1.
On RasPlex the streams are working fine.
