Hi, I am the proud owner of a new TVS-471-i3 and I just loaded all 4 bays with 6 GB 7200 RPM SATA Toshiba X300 drives and maxed the RAM out to 16 GB with the 2 x 8 SODIMM kit before I realized that the TVS-473 may have been the device I should have purchased. The fact that paid more than $100 more than I should have from Amazon means I could still return it and get the TVS-473 if I wanted to. The thing is, do I want to?
I realize that this is a Plex forum and not a QNAP forum, but since I really want my media library to use Plex as its backbone, and since I know a lot of of people here have had experience with both I have read the pros and cons of either. Yes, I know the TVS-473 has 4 x SODIMM slots rather than 2 for the 471. Also, while the 471 has the Intel i3 dual core chipset, it would appear that reports have the ARM quad core chipset of the 473 performing better. The 471 is over two years older, while the 473 is just out, but newer isn’t always better. For instance, the lack of locks on the 473 is a bit worrysome.
Still, the feature list of the 473 seems to make it the most conducive choice if I want the make VMs on my QNAS to not only have a VM for PMS, but to have one or more VMs to be the media player running either PLEX Media Center or even Kodi if I wanted to have that option. While QNAS doesn’t really market the video chipset of the 471 at all, the pushes how the 473 sports a Radeon GPU among other things, leading a buyer to believe it makes the better all-around media center. That may be the case out of the sheer fact that it is newer and will be supported with newer software rather than the hardware, but honestly it’s hard to distinguish marketing hype from real stats.
Finally, I did have a NVidia Shield (the Standard, not the Pro) but I sent it back because the device actually lacked an IR receiver, unlike the pro which has one. Since I want to have universal remote solution (which will either support IP controls or IR via a signal blaster) and unless I make some sacrifices the Standard Shield simply can’t do it unless I make it boot right into Kodi or something. The idea of spending another $100 for the Pro version just to have an IR receiver seems offensive since I clearly do not need the storage space. It’s sad because the Shield is otherwise a great device that is hobbled by not having a basic IR receiver, and from what I read, none of the USB IR receivers worked particularly well with the shield. This is why I am trying to just make the QNAS be the one device to rule them all, which is why I am leaning towards the 473 and since I got gouged on the 471 and still can return it under Amazon’s price guarantee, I am leaning towards doing so if I plan on making it my all-in-one device. It would seem that the amount of work needed to get there is less. Also, I have a a Pioneer SC-99 and I really would like to get Atmos going and getting a 4K TV is imminent as well.
So while this may not be the best place for this question, if you have experience with either device and have advice to offer someone who is looking to make either the TVS-471 or TVS-473 both their storage solution as well as their set-top solution, I would be grateful to hear your story. (I am going to take some of my post and start a thread in the QNAP forum even though the information there literally flies over my head at Mach 3, and I thought I was on top of my stuff w/r/t both server and A/V tech.)
Thanks in advance.
PS: For TVS-473 owners who have the 8GB version, does the RAM come with all 4 slots full with 2 GB SODIMMS or does it just have 2 of the 4 slots loaded with 4 GB SODIMMS? I think I know the answer, but I wanted to check first. Thanks.
