So I have this section of youtube downloaded vids and some other misc web vids in a “home videos” section. Iv been trying to find a way to queue them. Preferably to queue all unwatched to play after eachotheR. Regular queue from context does not seem to work as doing so either starts that video instantly or it just trys to load instantly and fails. can’t queue from library using the web interface either wich i find stange. This might not be a rasplex specific lack of feature, but I thought id ask anyway.
So has anyone found a way to generate a video playlist. Either with some skin mojo or some workaround to get a bunch of vids to play after eachother? thanks.
If you select a folder in a section and press play, it queues all items wthin that folder
this works for me if i want to queue up 32 peppa pig episodes to keep the boys happy.
And i'm not using a keyboard but a windows MCE remote
This did not work for me on PHT so i'm pretty happy that this little box as its a make or break issue as you can see
Although i'm having problems getting it to play all images in a photo folder using this method, but thats another issue
As a side note, it's a know issue with PHT legacy that some playlist features are broken.
They should look at this in a near future :)
