Rasplex composite doesn´t work
Hello,
my Raspberry PI (Model B, first Version) won´t work on my old TV.
I have a Composie Cable with Composite-Scart Adapter and forced sd_tv in the config.txt, but i have no signal on my old TV.
Here is my config:
#      This file is part of OpenELEC - http://www.openelec.tv
#      Copyright (C) 2009-2012 Stephan Raue (stephan@openelec.tv)
#      Inspired and partly copied from:
#  http://youresuchageek.blogspot.fr/2012/09/howto-raspberry-pi-openelec-on.html
#  This Program is free software; you can redistribute it and/or modify
#  it under the terms of the GNU General Public License as published by
#  the Free Software Foundation; either version 2, or (at your option)
#  any later version.
#  This Program is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
#  GNU General Public License for more details.
#  You should have received a copy of the GNU General Public License
#  along with OpenELEC.tv; see the file COPYING.  If not, write to
#  the Free Software Foundation, 51 Franklin Street, Suite 500, Boston, MA 02110, USA.
#  http://www.gnu.org/copyleft/gpl.html
# Bootloader configuration - config.txt
Memory (System/GPU configuration )
default GPU memory split (do not change if you do not know what you are doing)
gpu_mem=128
SDRAM size based GPU memory split, uncomment and setup to override ‘gpu_mem’
gpu_mem_256=54
gpu_mem_512=128
Overclocking settings
WARNING: Do not change/enable if you do not know what you are doing!
The System may become unstable or you can have data corruption or
you can loose your warranty if you set wrong settings
please read: http://elinux.org/RPi_config.txt#Overclocking_configuration
Overclock mode settings.
default recommended values are: arm_freq | core_freq | sdram_freq | over_voltage
no overclocking : 700 | 250 | 400 | 0
mode ‘Modest’ : 800 | 300 | 400 | 0
mode ‘Medium’ : 900 | 333 | 450 | 2
mode ‘High’ : 950 | 450 | 450 | 6
mode ‘Turbo’ : 1000 | 500 | 500 | 6
arm_freq=900
core_freq=333
sdram_freq=450
over_voltage=2
set to ‘force_turbo=1’ to disable dynamic overclocking (you can lose your warranty!)
force_turbo=0
If you have any data corruption using Turbo Mode and overclocking
try with this setting uncommented
If this still fails, try to use Medium mode without “over_voltage=2”
If it ultimately keeps failing, forget about this until it gets fixed
Use a more conservative mode that will works fine in any cases:
initial_turbo=30
Overscan settings
Make display smaller to stop text spilling off the screen
see also http://www.raspberrypi.org/phpBB3/viewtopic.php?f=67&t=15700
overscan_scale=1
disable_overscan=1
Adapt overscan values to your needs
overscan_left=57
overscan_right=59
overscan_top=20
overscan_bottom=20
various settings see also: http://elinux.org/RPi_config.txt
Force HDMI even if unplugged or powered off
hdmi_force_hotplug=1
sdtv_mode=2
sdtv_aspect=1
License keys to enable GPU hardware decoding for various codecs
to obtain keys visit the shop at http://www.raspberrypi.com
decode_MPG2=0x00000000
decode_WVC1=0x00000000
decode_DTS=0x00000000
decode_DDP=0x00000000
>>>>>>>> RasPlex default settings override <<<<<<<<<
hdmi_drive=2
gpu_mem_256=64
gpu_mem_512=200
End of default configuration
all values below this line were inserted from config.txt.bk (your old config)
and can be merged with the above values
Can anybody help me?
And sry about my bad english, I´m german :D
hi,
try commenting-out all "hdmi_force_hotplug=1".
- scott
Now, it’s working.
thanks a lot
