RasPlex Installer
Does anyone know when the 1.0.1 installer files will be back online, keep getting error 404 when I go to redo unload them.
until the website is available again, you can use the instructions from ‘PMP embedded’
https://support.plex.tv/hc/en-us/articles/212523657
All of the releases can be downloaded from here https://github.com/RasPlex/RasPlex/releases
@OttoKerner Thank you so much. Perfect.
@NedtheNerd said:
All of the releases can be downloaded from here Releases · RasPlex/RasPlex · GitHub
Forgot about that, yes. Although it requires abit of scrolling to find the link to the installer.
Both of you, massive thanks, any idea which is the version for writing from a mac to SD card for RasPlex? tar.gz or img.gz
Download the installer here Install Rasplex using GetRasPlex for OSX or Windows GUI · RasPlex/RasPlex Wiki · GitHub
Will have a look at the rasplex.com website, seems to be some problems, sorry.
Regards
.img.gz
Thank you guys YOU ARE AWESOME
Rasplex.com back up and running OK.
The issue was caused by GitHub updating their version of Jekyll.
Regards
Just wanted to report that, :smiley:
https://twitter.com/jammsen/status/703607159406329856
Remote control is already there.
https://support.plex.tv/hc/en-us/sections/200276908-Plex-Companion
See it in action
pay attention at 01:10
