Rasplex not showing up on "Now Playing"
With Rasplex 0.3.1 on PMS 0.9.8.10 (with PlexPass), what is viewed does not show up on "Now Playing" on the server or through the API. Rasplex is signed in to the server with a pin and claims to be logged in when I look in settings on the RasPlex box.
Thanks!
 -y1
Now Playing is not implemented yet in Rasplex  :(   :(
Are there any plans to support Now Playing on future Rasplex releases???
I hope this gets fixed asap. The Trakt.tv plugin is dependent on this working.
The feature required a merge with a later version of PlexHT that has the ability to work with Now Playing.  This is currently working in an experimental (very beta) build, so it will be available in the next release.
