I’ve installed rasplex on a spare Pi B+ and it can play some movies, but others are transcoded (Bluray rips to mkv).
Will a pi-3 be able to play all movies without causing the server to transcode?
Here is a movie that transcodes (copied from pms -> media info):
Media
Video Resolution 1080p
Duration 2:12:39
Bitrate 4856 kbps
Width 1920
Height 1088
Aspect Ratio 1.78
Container MKV
Video Frame Rate 24p
Video Profile high
Part
Duration 2:12:39
File American_Sniper.mkv
Size 4.50 GB
Container MKV
Video Profile high
Codec H264
Bitrate 4216 kbps
Language English
Anamorphic 0
Bit Depth 8
Chroma Subsampling 4:2:0
Frame Rate 23.976 fps
Height 1088
Level 5.0
Pixel Aspect Ratio 138:137
Profile high
Ref Frames 5
Scan Type progressive
Width 1920
Codec AC3
Channels 5.1
Bitrate 640 kbps
Language English
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Title Surround 5.1
Long answer: Yes, assuming your settings are all correct (standard setup will do it) and there are no strange anomalies anywhere within your network. I have two 3’s and they’ll both do a HD Blu-ray with full DTS-HD Master Audio at the same time, streaming from a server salvaged from an old computer that was build in 2009!
Additionally, most of my movies are quite large in file size, some being up to 20gb (LOTR trilogy - each film) with both DTS-HD MA or Dolby TrueHD (disc dependant) and AC3 audio for compatibility. The Pi3 makes light work of them.
