Recently updated Xbox App showing title through episodes and movies
@PolikosFoinix said:
So the answer is to remove yourself from the Beta/Alpha build of XBox instead of whatever is going wrong with Plex to keep the Title constantly displaying in the middle of the screen… doesn’t seem like a very good answer to me.
It’s the only answer I’m afraid. As already mentioned the cause of the issue lies with the Insider ring OS builds, and not our app. Microsoft are already aware of the issue and are working on a fix. In the mean time if you want to avoid the issue then you need to jump back to the public OS build, and not the alpha ring builds.
I have found that if I hit A on the controller, then go to Player settings. Change the Audio stream from AAC Stereo to AC3 5.1. Then go back to the movie it goes away. Sometimes I have to switch back again to AAC Stereo, go back to the movie, then Choose AC3 again and it stays gone for the duration of the movie. Not sure why it defaults to AAC Stereo either, but I need to search the forums for that. I know it’s a separate issue.
