Hey kids…
Here’s a weird one. I’m running the latest Plex Server (updated just now actually) and the latest OpenPHT which I love and tell everyone about. I use the Recently Watched Shows filter quite a lot to keep track of what I’m binge watching. Recently I was in the TV Shows and the cat stepped on my keyboard. I don’t know what she typed or what combination she hit but now when I go into the Recently Watched Shows it displays them alphabetically and shows the entire library. Recently Watched Episodes is still correct by Date Watched and I can see in the Plex Server GUI that everything is still updating correctly it just seems that somehow, Recently Watched Shows got sorted by name instead of date. Plex Home Theater is doing the same thing so I don’t think it’s OpenPHT. But since that forum is dead I thought I would check in here.
Anyone have any idea on how to fix this barring a complete uninstall and reinstall? Also, I did try putting the cat back on the keyboard to re-create it. No luck besides getting a few scratches.
Peace
Plex Broke the ‘recently watched shows’ in a recent PMS update unfortunately. now it only returns all shows instead.
Damn them! Well that answers my question. Due to timing it just looked like my cat’s fault. I guess I’ll go give her some tuna to apologize.
Thank you for the quick response.
I also use this filter feature alot for shows, and it has stoped working since the latest PMS update.
But i’m not sure plex “broke” it like you say, because it still works perfectly on the ios and android apps. It just stoped working on PHT and openPHT.
I hope there can be a fix, because i hate the pathetic PMP, and really love openPHT (or the old PHT, which i still use).
if your using the old PHT then complaining here isnt going to fix it for you, they havent worked on the original PHT for a long time, its outdated and dead
anything we do to fix/workaround it it is only going to effect openpht and rasplex and not PHT
if you really want it to be fixed right now for your PHT you could downgrade PMS 6-8 releases, i forget which one became broken in
FYI the workaround for this is by going to All Shows, then sortng by ‘Date Viewed’ which will give the same results
it uses a different api call so thats why that works
hopefully the next version of openpht/rasplex will workaround this
that’s what I get from upgrading from 1.0.3
every time I upgrade it seems there is something new that’s broken… sigh
thanks for this tip, that worked fine!
