I was wondering why Plex ended up giving all tracks of an album empty titles.
The problem is with this line in Plex Music Scanner.py:
Thanks, I've reported the bug here ~ https://github.com/plexinc-plugins/Scanners.bundle/issues/33
In order to prevent overwrites, make the bundle a symlink if your OS allows it. The updater will ignore symlinked bundles.
Didn't know there was github. (Plex is not open source, is it, so I assume the plex team pays for it?) Do they also accept pull requests?
Didn't know there was github. (Plex is not open source, is it, so I assume the plex pays for it?) Do they also accept pull requests?
all the agents are open source (as are several of the clients and most channels)
I was confused because the file Plex Music Scanner.py says:
## Copyright (c) 2010-2011 Plex Development Team. All rights reserved.#and does not specify under which license the code is distributed.
might just be the "Plex, anyone with good ideas can contribute" license.
