[REL] DevTools
This channel is no longer maintained, and has been replaced by WebTools
Yep....A release in the Dev foras, but that's where it belongs  :D
This is a small bundle, that can assist 3. Party developers, running outside the Plex framework to still access information from the framework
Currently return information, that can not be grasped from the http interface, or manipulate the file-system.
Need something, then do come with suggestions on what to do, and I'll see what I can do, or even better, fork it, implement it, and create a pull request for it
The information/functions it currently provide is the following:
https://github.com/ukdtom/DevTools.bundle/wiki
Download it from github:
or install it via The Unsupported AppStore
Edit: 09. Oct. 2014 Released V0.0.0.8
Edit: 28. Sep. 2014 Released V0.0.0.6
Edit: 28. Sep. 2014 Released V0.0.0.5
Edit: 28. Sep. 2014 Released V0.0.0.4
Best Regards
Tommy
remove the -master from the folder name when you install it.
Released V0.0.0.4:
From the changelog:
V0.0.0.4:
- Added the following:
DelFile(Secret, File)
Note: remember to fill out spaces in the filename with %20
V0.0.0.3:
DelOSSrt(Secret, Bundle, SrtFile)
V0.0.0.2:
- Switched away from using prefs....Note that it's not backwards compatible with V0.0.0.1
Returns the path to ~Library/Plex Media Server
GetLibPath(Secret)
Returns the contents of an xml file
GetXMLFile(Secret, Path)
Return the version of this plugin
GetVersion(Secret)
Return the contents of an OpenSubTitle XML file for a bundle
GetOSXml(Secret, Bundle)
NOTE: This release is not backwards compatible with release 0.0.0.1
See first post in this thread for download instructions
Happy Plexing
/Tommy
Released V0.0.0.5:
Changelog:
PathExists(Secret, Path)
/Tommy
Released V0.0.0.6
From the changelog:
-Added the following:
ShowSRT(Secret, FileName)
Happy Plexing
/Tommy
Released V0.0.0.8:
(Version 0.0.0.7 never made it public)
From the changelog:
			V0.0.0.8:
			- Removed DelSRT function
			- Added DelSub function
			<p style="margin-left:40px;">* Initially same function, but now also works for other ext. than srt</p>
			&nbsp;
			<p style="margin-left:40px;">* DelSub(Secret, MediaID, SubFileID)</p>
			&nbsp;
			<p style="margin-left:40px;">* Call like: <a data-ipb='nomediaparse' href='http://PMS:32400/utils/devtools?Func=DelSub&Secret=1234&MediaID=2&SubFileID=109'>http://PMS:32400/utils/devtools?Func=DelSub&Secret=1234&MediaID=2&SubFileID=109</a></p>
			&nbsp;
			- ShowSRT
			&nbsp;
			<p style="margin-left:40px;">Fixed (Hopefully) error when detecting an non UTF-8 caracter</p>
			&nbsp;
			&nbsp;
			&nbsp;
			V0.0.0.7:
			&nbsp;
			&nbsp;
			<p style="margin-left:40px;">DelFile now refuse to delete an srt file</p>
This bundle has ended, and been replaced with WebTools, that has an open API for 3.Party devs
github.com/dagalufh/WebTools.bundle/blob/master/Contents/Code/Docs/webtools-README_DEVS.odt
Thread closed
