[REL] Extended Personal Media Shows Agent
Those are all good questions:
  1. If you are using a date based media file and you check the "Include date in title" option then name will be MM/DD Episode title from the file (for example: 08/08 Enfance). If you uncheck the option the episode title will be Enfance. I am thinking about changing the plugin to allow a user to specify a naming standard for episode titles. Let me know if this would be useful.
  2. As of right now the summary is just the episode title. I will test updating of a manual written summary and let you know. For my personal needs I don't ever specify a summary. I had thought about enhancing the plugin to look for a filename-summary.txt file in the same direct as the media file to use in loading the summary in Plex. Let me know if this would be useful.
  3. You should be able to add spaces, periods, etc after Enfance. My files are all multi-word titles and I haven't had any issues. Maybe you could provide me the exact file name for testing purposes.
First of all, you're doing a great job, personal videos are tricky to index especially when all needs have to be satisfied.
1. The MM/DD choice is a good one, I didn't realize that the full date was one the video image anyway...
2. I don't use summary (for now) either but I think you should think about an option by default that would not erase an existing summary if it exits.
3. I called my second movie "Enfance 2" by the "2" didn't show up perhaps because it's a number, I'll try with text.
Thanks for the kind words. The personal media shows in Plex has always been something that I wanted to enhance. If you have any ideas on something else that would be useful let me know.
  1. That's why I had removed the year. I had originally included the date in the episode title because I thought it might cause Plex to sort the episodes in the correct order. Right now they are not sorting by the episode date but by the episode title.
  2. I tested an existing summary scenario and as long as the field is locked it will not be overwritten by my metadata agent.
  3. This is an interesting test case. I created a test file on my server too and it appears that Plex is treating the 2 as a part 2. My plugin actually doesn't see the 2nd file. Plex just uses the same episode title as the first file (i.e. Enfance). This seems like a possible bug. You can actually use stacking with this plugin as long as you use the partX or prtX format. I currently do that with some of my personal media files.
I would like to thank you for this agent as well!
Love PLEX; it works great with Movies and TV Shows and with your agent is now able to properly display my home videos as well...
I tried the folder structure without separating individual Seasons/Years and it still works fine (as long as the date is in the title it automatically breaks it into years).
Not quite sure about local artwork; had some limited success with show.jpg.
I have just one question:
Type of media has to be TV Shows to end up with a structure, how do I check options you mentioned like include date?
Cheers
Franz
The local artwork does work if you follow the folder structure from the first post. This is how I have my home videos setup and it works great.
To include the date in the episode title you need to go to Plex Settings > Plex Media Server > Agents > TV Shows > Extended Personal Media Shows. Once there you can click on the gear icon next to the Extended Personal Media Shows agent to show the options. After you have enabled the "Include the episode date in the show title" option refresh your metadata.
As I mentioned above let me know if you have any plug-in ideas that you would like to see implemented.
Thanks for sharing nice agent. This will make great addition.
Couple of questions before i play with it over the weekend:
1, Can i choose human readable date format ? (instead of having 2013-10-10 in the title to have October 10, 2013 or Oct 10, 2013)
2, IsĀ embeddedĀ metadata read in case it is provided ? (Like description etc ..)
  1. Right now the only option is to include the date at the beginning of the episode title - for example MM/DD Episode Title. In the near future I will probably an episode title mask to the plug-in options so that users can chose their own naming convention.
  2. The extended personal media metadata agent only sets the episode title and summary. The rest of the data comes from the Plex local media metadata agent. The local media metadata agent should be able read the values from the underlying media and update the file. I will test this out though and see if it is working correctly.
1, I meant displaying date in PLex ( ie not file name ) so for example file /TVShows/Formula 1/2013/ Formula 1 - 2013-10-10 - Grand Prix of India.mp4 would show up in Plex as a Formula 1(show),Season 10(season), Grand Prix of India, Oct 10, 2013(episode title). (sorted as a daily episode based on the date of course)
2, Where does the summary currently come from ?
Managed to get the artwork to work and found the settings to turn the date on and off for the agent.
I have just one wish: I had troubles with subtitles; can they be supported?
(I use them to show the date & time that I have recorded my home videos and find it very useful to be able to turn them on and off)
The subtitle is just a file with the extension ".en.srt" with the same file name and works fine with the original personal media agent
Thanks!
Dear mjarends,
I would have one new but important request for files date tagging. It appears that that the date format is always the US one i.e. "MM/DD".
I would be grateful if you could add the option to choose the european format "DD/MM".
Thank you
  1. I have just updated the plugin to allow the user specify the episode title and summary template. See the original post for instructions. To get the title like you want you would need to go to the agent configuration in Plex and change the "Template to use in creating the date-based episode titles." to ${episode_title}, ${episode_date|%b %d, %Y}. Refresh your metadata in the section after you have made the change.
  2. Currently the summary is also generated by the agent from the file name. I have thought about adding functionality for reading the summary text from a -summary.txt file in the same directory as the media file.
Thanks!
I tested subtitles in Plex and I can't get them to work with the Plex TV Personal Media Show agent. Were you using the Plex Movies Personal Media Agent? I will look into this a little further. Currently the agent I developed only sets the title and summary and is relying on the Plex local media agent to retrieve the rest of the data.
Dear mjarends,
Thank you
Check out the latest plugin and original post. I have updated the plugin to allow the user to specify the template to use in creating the episode title and summary. To get the title like you want you would need to go to the agent configuration in Plex and change the "Template to use in creating the date-based episode titles." to ${episode_date|%d/%m} ${episode_title}. Refresh your metadata in the section after you have made the change.
Thanks a lot
One little thing, what is the exact language reference, I have a French system but I can't manage to get full months in my language, they're still in English. On the strftime reference guide, it is supposed to be a "local" name.
It seems that files with the same date in the same season folder have the same title. Ā
For example I haveĀ
NFL - 2013-10-20 - Week 7-Broncos Vs Colts.mkv
NFL - 2013-10-20 - Week 7-Patriots Vs Jets.mkv
Both episodes have the same title "Week 7-Patriots Vs Jets"
The same thing is happening for the Week 8 games.
File structure:
![post-60425-0-24849000-1383227047.jpg|299x189](upload://oBLftCBvrwdklTQD4nhxZZqglUl.jpg)
View in Plex Web
![post-60425-0-47035900-1383227055.jpg|690x371](upload://xE5DceC5uLEVoCX2WW8dUReASAR.jpg)
Log attached too.
Any ideas?
Thanks for your work on this agent.
Can you look at the plug-in log (the file name is com.arendshome.plex.agents.personalmedia.log) and find the following line. What does it say on your server? If you want you can an also attach the log for me to take a look at.
2013-10-31 09:50:25,127 (2198) :  INFO (localization:408) - Setting the default locale to en-us
Indeed, I have this exact line with setting in "en-us", how could I change it?
Nothing on my server is configured in English, everything in French.
For example I have
File structure:
View in Plex Web
Log attached too.
Any ideas?
This is actually caused by the Plex Media Scanner which only allows for a single TV episode with the same date - it is equivalent to an episode number. Because there is already an episode (Week 7 - Patriots Vs Jets and Week 8 - Washington Vs Broncos) the scanner just reuses the same names. One way around it is to change to using the sYYYYeMMDDG format where you would have YYYY = 2013, MM = 10, DD = 10, and G be your game number for the day. This weekend I plan on creating a Movie Personal Metadata Agent that might work better for you in this scenario.
Played around with it a bit more and it seems that PLEX is a bit flaky with subtitles and personal shows...
There is no difference between your personal extended media agent and the personal media agent provided as far as I can tell.
When I start a brand new section the subtitles work but once it gets a bit populated it gets confusing. I ensured that the local media agent is ticked, still a bit of hit and miss.
Maybe Ill just have to start with the videos that have subtitles first and then add all the rest later.
Still, your agent is great!!!
