Remote Access - Not available outside your network
Server Version#: 1.43.3.10896
Player Version#: 1.115.0.426-4e960a1d
Machine Identifier: 72ce5478789a7017c3a08d6f34d3490ef40718be
Platform: macOS (native install)
Summary: Remote Access shows Not Reachable. Server recently migrated from a Docker container (Orbstack) to a native macOS Plex install, settings copied over.
Preferences.xml shows the server’s current local certificate identity:
CertificateUUID=“2ef838a34f0746e780fe467ac06fe156”
CertificateVersion=“3”
But the reachability prober is testing a different, older UUID entirely:
HTTP error requesting GET https://[WAN-IP].19664b774adc4c108e7a1c39e12fd5d4.plex.direct:32400/identity (60, SSL peer certificate or SSH remote key was not OK) (SSL certificate problem: unable to get local issuer certificate)
Confirmed the port and network are fine:
  • Port 32400 verified open via third-party checker
  • Local /identity check on localhost:32400 works
  • System curl against the plex.direct URL above returns a fully valid cert (Let’s Encrypt, CN=YR1, expires Oct 30 2026, verify OK)
  • Only PMS’s own internal reachability check fails, and it’s checking a UUID that doesn’t match what’s in local Preferences.xml
No stale cache directory or leftover plist entries found, those were ruled out first. This looks like a mismatch between the local server identity and what’s cached on Plex’s side for this machine identifier. Could someone reset the server identity/certificate record for this machine identifier? Thanks.
Mac’s don’t use the preferences.xml file, that’s likely left over from your migration from your old server. Macs keep all the data that’s in the xml on Linux in a plist file on a Mac.
Since you’re on a Mac, I would suggest the steps below to see if forcing a new cert will help.
Stop plex, go to the folder in the path below and remove the certificate from the folder, *.p12, and restart plex so that it pulls down a new certificate. If that doesn’t fix it, may need someone from plex to refresh it on their end.
/Users/<username>/Library/Caches/PlexMediaServer
I was looking in the wrong place for the Cache directory. That fixed it. Thank you so much!
