Remote address is showing wrong ip address
Server Version#: 1.16.3.1402
Server is showing the IPv6 ip address instead of the ipv4 making any remote connection indirect.
This only started after updating to the newest version of the server.
I have tried restarting plex, and restarting just the remote server.
Any other suggestions?
did this " Enable server support for IPv6 " get set
it did for me when the upgrade was done, had to uncheck it.
I never noticed before. Thank you. Is there any advantage to using the ipv6?
Don’t know… I’ve always had it disabled…
I noticed after the upgrade ipv6 address showing up so I looked and disabled it.
Ok. Thanks for letting me know. I unchecked it and don’t seem to have the problem anymore
