Replacing older NAS - Recommendation requested
I currently have a ReadyNAS 516 @ 36TB roughly 78% capacity.
I have had PlexPass for years and have always enjoyed my setup. Want to be sure I am able to transcode efficiently.
Going to replace the server H/W and these are in my head thus far.
QNAP TS-653D
QNAP TS664
Synology DS920
Asustor AS6706T
Any other capable system recommended would be appreciated. Each of these diskless are under $1,000.
Thoughts? Please and Thank you.
Do you need additional storage?
If not, run Plex Media Server on a PC running Linux and leave the media on the NAS. If space is a consideration, get an Intel NUC or similar small form factor computer.
This gives you the potential of a much more powerful Plex server, with an i3/i5/i7/i9 CPU versus a Celeron.
Regarding your NAS list, mark off the DS1522+. It has an AMD CPU, so no hardware accelerated transcoding with Plex.
Thanks. Appreciate the input. Yes, upgrading storage to feed my addiction. :smiley:
You may want to check in to Ready Nas or Unraid. I personally run Unraid and have for years, it has worked grate.
All ReadyNAS are end of life products. That was my first stop since I already run a ReadyNAS.
I upgraded to Synology DS920+ and am very happy with it. I had my PMS on DS916+ before and was running out of space. Decided to throw in for new NAS and DS920+ seemed to be best all around for PMS. It plays 4k content without issue within and remotely from network even when transcoding.
Good to know, I did not know Ready Nas was EOL. As I said I use Unraid.
UPS will be delivering a QNAP TS-664, (2) 1TB M2.SSD for the OS/Apps and (6) IronWolf 16TB drives for storage in RAID 5.
Went with the QNAP ultimately because of the specs, and perceived QNAP saturation here in the forums. I intend to install and crash it 4 times in the first 2 weeks before I get serious about the Plex build. I need to be comfortable/familiar with the EMERGENCY REBUILD procedure before I go all in. LOL
For those who run a QNAP ANY AND ALL tips will be appreciated.
Not a QNAP user, but having this link on hand is recommended: Qnap faq.....read me first!
Enjoy! Hope it goes smoothly for you.
ChuckPa posted this in another thread not too long ago. Might be worth a look
Final note on this adventure. As I said, I purchased a TS – 664 from QNAP Systems Inc. I can say that on the Plex side it is flawless! Plenty of power, transcoding is seamless. Hi-res, lo-res, multiple streams, etc. I am thoroughly impressed. There are some advantages that I am enjoying over the ReadyNAS and it was ultimately the correct/upgrade purchase for me.
