[REQ] Filter by Audio
There is already a way to filter via video; to see standard definition at the top and then it scrolls down to high definition.
I would like a means to filter by audio(for video), which would be 2.0 audio at the top and then progress to 5.1 audio.
This way, I would know which video files need to be updated/upgraded.
Agree. +1000
Yes, it should be an easy addition.
I would be fine with the filter only working through the PLEX on the PC…
Just upgraded to a 5.1 setup, I’d really love this feature, the only apprehension I’d have is plex ability (or most players) to recognise and play the correct track. Some stuff that’s 5.1 dd or atmos and especially aac seem to be producing different tracks to my system (ie not recognising the dd etc.)
If you just need a list which items to upgrade, I recommend you Plex2CSV.
It’ll give you a CSV file with selectable detail, which you can open and filter and sort in a spreadsheet app like Excel and the like.
Have you actually used Plex2CSV? I just installed it based on your recommendation.
And none of the filters concern audio.
Of course I used it. I helped dane22 betatesting it.
You must set the detail level in the preferences of this plugin.
Set the Movie Export Level to ā€˜Level 666’ and you’ll get all data there is.
ā€˜Audio Channels’ gives you the number of channels ā€˜2’ for stereo, ā€˜6’ for 5.1 surround
ā€˜Audio Codec’ gives you the type of audio
'dca-ma' for DTS Master Audio
'dca' for normal DTS
'ac3' for Dolby Digital
'mp3'
'mp2'
'aac'
'truehd'
etc.
ā€˜Audio Stream bitrate’ gives you, well, the bitrate of the audio stream(s)
ā€˜Audio Stream Bit Depth’ is usually 16 or 24
ā€˜Audio Stream Bitrate Mode’ gives you either vbr or cbr for ā€˜variable’ or ā€˜constant’ bitrate mode
ā€˜Audio Stream Sampling Rate’ is also there
That is plenty of technical detail.
Well I can admit when I am wrong, in a sense…thanks for the information in expanding the technical detail.
Yet, it seems that for some reason in that "Audio Channel’ Column - months will be listed.
Like it will state Feb 2nd or Jan 6th. Even checked to see if that date corresponds with the number of audio channels…it doesn’t…
I have that too, but only if I open the CSV in Excel. Excel tries to be ā€˜smart’ by interpreting the string 2/2 and 5/1 as ā€˜dates’. You can check what’s actually in the file by comparing and opening the CSV in a text editor.
This happens when there are several files for one item, for instance when you have ā€˜optimized versions’ of a movie or the movie has stacked files.
If you open the file in LibreOffice, there are fewer of these ā€œquirksā€.
