[REQUEST] Move from SQLite to MySQL or Postgres
+1 for this! I would love to move plex into my postgres server.
Adding my two cents in support. I’d love to see Plex support databases other than SQLite3, preferably MariaDB/MySQL or PostgreSQL. Even just turning the database link into a POSIX socket with a default SQLite3 backend would allow users to put their libraries in a variety of faster, multi-threaded databases. SQLite just isn’t made for real workloads. Help us love Plex even more!
ummmm. Bump! This need priority
Don’t !
This is voting based!
Another enthusiastic yes, please! SQLite3 is designed for small, temporary databases, not a library you’re using every day. Please, please, please allow us to use other backends (e.g., MariaDB/MySQL, Postgres) for the Plex library database.
+1 to supporting other databases at a high priority.
I’m tired of the famous db is busy waiting 200 seconds issue.
I’ve upgraded to SSD and it only cut down on this issue while I’m only at 70TB of media and it’s only Myself, wife, and children that watch this.
I have mysql servers that get hit harder than this on lesser hardware without issues. It seems like an oversight in programming that this was set up in such a manner. Not to mention the fact that this sqllite db has wound up getting corrupted 3 times in the last 3-4 years. I have a mysql instance I use for numerous applications and I’ve never once dealt with a corruption issue.
I don’t even see myself as a power user, yes there’s quite a bit of content downloaded, but with a max of 4 people watching as mentioned previously, when no new content is coming in and yet these issues being present, it seems like you put a bottleneck in to your own application due to oversight in design…
Please take this seriously, make your application better, that would only make people happier.
Please, with the increase on number of tv show it’s becoming a requirement!
Give us options or better database!
I would encourage anybody who is having performance issues and is wondering about SQL problems to open a new topic for discussion and troubleshooting.
I am aware of several instances where databases became unnecessarily large, which slowed things down. This wasn’t a SQLite issue, but fixing the data problems made a big difference.
I wish Plex allocated more cache to SQLite, but you can hack a quick 5x increase.
How big are people’s .db files?
com.plexapp.plugins.library.db = 283 MB
com.plexapp.plugins.library.blobs.db = 1.2GB
I’ve optimized my DB for a 16K ZFS recordsize. It’s on six drive SSD raidz2. Even running from a ram drive does not seem to add any performance increase as I’m still seeing alerts in my logs about slow performance. ChuckPA came to the conclusion that I’m most likely CPU bound as I’m only running a 8 core 16 thread E5-2650 v2.
SQLite is a very bad option for a massive mediavault. Please implement MariaDB integration asap. Thank you.
I want to vote to for a external database asap. Would be very very beneficial
Thank you
SQLite is a very bad option for a massive mediavault. Please implement MariaDB integration asap. Thank you. +1
+1 to supporting this as well
+10000 to supporting this.
Perhaps the devs could use SQLAlchemy in PMS so those of us who want to use a different database can use one. I do this now with HomeAssistant. It has SQLite as the default database but I use MS SQL Server for similar performance reasons listed above. It works very well.
https://www.sqlalchemy.org/features.html
SQLAlchemy includes dialects for SQLite, Postgresql, MySQL, Oracle, MS-SQL, Firebird, Sybase and others, most of which support multiple DBAPIs.
Big plus one for this. Postgres makes the most sense because it’s licence allows for redistribution as part of the package. This is the most obvious and most effective performance upgrade Plex could have
This is needed, I had to split my server out into three different instances as having a large music library absolutely crippled my servers performance
how big is it? i have many and my server performs well
Just over 200k tracks after ripping my parents collection but I started seeing performance issues when I jumped from ~50k to 120k
i have over 600k. 95% audiobooks.
it is working well for me, bit iā€˜m sure a plex database has itā€˜s limits
as i want to add lotā€˜s of media in the future, and will buy expensive hardware, it’s important to have the best possible database system. but i canā€˜t say what that would be
+1
please give us external database to improve performance
