Return to shell
python PlexConnect.py &
isn't working on unRAID.  Anyway I can launch this and return to the shell?
http://forums.plexapp.com/index.php/topic/69402-do-you-need-to-keep-the-terminal-window-open/?p=401370
All.....you can cheat this by using: screen python PlexConnect.py
lots of Linux distro's have screen built in and there's a pkg for it for unRAID.
When you detach from this screen (CTRL A + d), you will now need to use the PID to reattach to. To do this issue
#screen -ls
This will return something like this:
# screen -ls
There is a screen on:
	10257.pts-2.hostname	(Detached)
1 Socket in /var/run/screen/S-root.
you then reattach with the PID i highlighted in red.
screen -r 10257
To make things easier, issue a 'nickname' to the screen session by doing this:
screen -S my_name_for_this_screen python PlexConnect.py
Or you can just type: screen -r to attached to the last screen session.  Only works if you have one screen session open.
