@spikemixture said:
Even the pro wouldn’t come close to backing up my primary server, capacity wise.
You have your terms mixed up.
The Shield or a HTPC are Plex Media SERVERS (and just to confuse things can also be players)
Now in your case your server also has your media (storage)
In the Shield’s case the media can be on the network or a connected USB device.
So using the Shield as a back up server means it is on your network getting the media from your HTPC.
Why would you want to do that ? Maybe your have several streams hogging the resources on you HTPC while you are trying to do something else on the PC = a game, photoshop , whatever…!
I thought I was clear until this comment. lol
I understand that my current “server” (Win10 box with lots of storage) is a media server that feeds all my streaming devices.
I understand that a Roku and a Shield (along with many others) are streaming devices.
I understand that a Shield can ALSO be used as a server, but since the max capacity is 500GB it wouldn’t come close to being a “backup” for my existing server which has 15TB+ of storage, most of which is media.
“So using the Shield as a back up server means it is on your network getting the media from your HTPC.”
I understand the “server” concept. What I don’t understand is how having a device with less than 1/10th of my current server’s capacity can “back up” anything in this regard. Are you saying that it will somehow know what I’m watching and copy perhaps some small, sub-section of it on the fly to stream from the Shield while I’m watching something? That’s what I don’t get. If that is what you are saying, how does that benefit me if I’m not currently having performance issues?
If by “it is on your network getting the media from your HTPC” you mean it is acting as a streaming device, that’s what my expectation is just like it would be using a Roku or any other Plex compatible streaming device. On my main, 65" 3D TV, I currently I use an ASUS HDMI stick computer running Win10 for example. I have a Firestick in my bedroom, etc.
I’m not trying to be a wise guy. I’m trying to understand. Thank you!
