RPi headless plexamp service not running after update to 4.5.3
RPi headless plexamp service not running after update to 4.5.3:
pi@pi4:~/plexamp $ node js/index.js
internal/modules/cjs/loader.js:1057
  return process.dlopen(module, path.toNamespacedPath(filename));
Error: Module did not self-register: '/home/pi/plexamp/treble/linux-arm64/treble.node'.
    at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
    at Module.load (internal/modules/cjs/loader.js:863:32)
    at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    at Module.require (internal/modules/cjs/loader.js:887:19)
    at require (internal/modules/cjs/helpers.js:74:18)
    at Object.41673 (/home/pi/plexamp/js/index.js:2:347063)
    at a (/home/pi/plexamp/js/index.js:2:2215301)
    at Object.65631 (/home/pi/plexamp/js/index.js:2:341356)
    at Object.10546 (/home/pi/plexamp/js/index.js:2:326583)
pi@pi4:~ $ systemctl --full --no-pager --user status plexamp.service
● plexamp.service - Plexamp
     Loaded: loaded (/home/pi/.config/systemd/user/plexamp.service; disabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Fri 2022-11-11 22:26:22 EST; 3ms ago
    Process: 1239 ExecStart=/usr/bin/node /home/pi/plexamp/js/index.js (code=exited, status=1/FAILURE)
   Main PID: 1239 (code=exited, status=1/FAILURE)
        CPU: 739ms
Per the release notes, you need node v16 now. Upgrade your node version and everything will be good.
Web page needs updating
Thanks, will do!
