ChuckPa
November 24, 2021, 5:48pm
41
How do we backup or export a VM which is located on datastore1 ?
(my ESXi knowledge is limited)
My goal is to be able to backup & restore.
(since initial creation, I now have 10GbE LAN for everything so don’t really need to run it from the internal 1TB datastore1)
I have never been successful with this fully. The time I used it I went through the wizard and it worked kinda-- I had issues with network devices which I recreated. Now the lab at work does this for me.
Oh cool you got it working. The steps to install the drivers on F35 if you haven’t done it are:
dnf install dnf-plugins-core
dnf copr enable jdanecki/intel-opencl
dnf install intel-opencl level-zero intel-level-zero-gpu
ChuckPa
November 24, 2021, 6:54pm
44
Next thing I need help with (for the 7000 and 8000 CPUs) - Beignet,.
Know where that might be?
Not that I know of. The copr project that I saw doesn’t work –
I was able to build beignet myself in F35, so it’s very possible.
Someone could create a copr project to build it for this. Not sure if anyone in plex team can do this.
I think plex though could change it’s architecture to not to use Beignet-- though my knowledge is lacking here. I know OpenCL 2.1 support is there for Intel 7th Generation.
ChuckPa
November 24, 2021, 8:06pm
46
I’m trying to get Engineering to free up the time to build Beignet / OpenCL for the NAS platforms. Still no progress.
IF ICR will work for the 7000’s and higher, meaning Beignet is not needed, then I am satisfied.
PMS doesn’t look for the specific packages by name. My installer does. It ensures the package(s) are installed for the transcoder to be able to get to the QSV ASIC (transcode) and the IGPU for tonemapping using OpenCL.
If it doesn’t need Beignet to get to the openCL layer for the tonemapping then great.
If that is the case, can you test if opencl works with 7th gen?
As for your script, looking at packages works, but for people who build (like me) or different distros, it would be better to check directly if the libraries exist using a combination of “ldconfig -p” where you can grep for libigc, libigdgmm, etc., and use a combination of “clinfo” which looks at /etc/OpenCL/vendors, and such as “LIBVA_DRIVER_NAME=iHD vainfo”
ChuckPa
November 24, 2021, 8:54pm
48
I thought about doing that then you run into the people , like Gentoo, who put their stuff all over the place.
I unfortunately NEED the standardization for support and documentation purposes.
[chuck@fedora ~]$ rpm -qa | grep -i intel
xorg-x11-drv-intel-2.99.917-51.20200205.fc35.x86_64
intel-gmmlib-21.3.2-1.fc35.x86_64
intel-igc-core-1.0.8708-1.fc35.x86_64
intel-igc-opencl-1.0.8708-1.fc35.x86_64
intel-opencl-21.38.21026-1.fc35.x86_64
intel-level-zero-gpu-1.2.21026-1.fc35.x86_64
[chuck@fedora ~]$
Those who are sufficiently skilled to know it’s right can safely ignore the warnings.
Those warnings don’t stop the installation. Warn != abort
I’ll continue to build the package here; create the postinstall; then start trial builds to see how badly I can break it.
When I get something that works, I’ll post it up ASAP
Great glad you are making it. I will try it once done. Thanks.
I guess either way to check, there are issues.
ChuckPa
November 24, 2021, 10:15pm
50
I’ll build first package tonight. %post is almost done.
FYI. other things you’ll get.
Nvidia detection.
udev configuration
Hand’s off installing in a container (docker or LXC). It does know to avoid the udevadm bug.
ChuckPa
November 25, 2021, 1:23am
51
Base scripting work is ready. cleanup to finish. Testing begins
[root@fedora output-all]# dnf -y install plexmediaserver-1.25.0.5263-f0d9679db.x86_64.rpm
Last metadata expiration check: 2:50:47 ago on Wed 24 Nov 2021 05:36:40 PM EST.
Dependencies resolved.
Package Architecture Version Repository Size
Installing:
plexmediaserver x86_64 1.25.0.5263-f0d9679db @commandline 96 M
Transaction Summary
Install 1 Package
Total size: 96 M
Installed size: 204 M
Downloading Packages:
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Running scriptlet: plexmediaserver-1.25.0.5263-f0d9679db.x86_64 1/1
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Installing : plexmediaserver-1.25.0.5263-f0d9679db.x86_64 1/1
PlexMediaServer install: 1.25.0.5263-f0d9679db - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: New
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: render
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Processor: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
PlexMediaServer install: Intel i915 Hardware: Found
PlexMediaServer install: Nvidia GPU card: Not Found
PlexMediaServer install: OpenCL: Not Installed
PlexMediaServer install: Beignet: Not Installed
PlexMediaServer install: WARNING: The OpenCL library, required for hardware transcoding of HDR content, is missing.
PlexMediaServer install: Please install package: 'ocl-icd-libopencl1'
PlexMediaServer install: INFO: dpkg will install package 'ocl-icd-libopencl1' automatically
PlexMediaServer install: if available for your host upon successful installation of Plex Media Server.
PlexMediaServer install: WARNING: The Beignet-OpenCL library, required for hardware transcoding of HDR content, is missing.
PlexMediaServer install: Please install package: 'beignet-opencl-icd'
PlexMediaServer install: INFO: dpkg will install package 'beignet-opencl-icd' automatically
PlexMediaServer install: Completing final configuration.
Created symlink /etc/systemd/system/multi-user.target.wants/plexmediaserver.service → /usr/lib/systemd/system/plexmediaserver.service.
PlexMediaServer install: 1.25.0.5263-f0d9679db - Installation successful. Errors: 0, Warnings: 2
Verifying : plexmediaserver-1.25.0.5263-f0d9679db.x86_64 1/1
Installed:
Complete!
[root@fedora output-all]# ps -ef | grep -i plex
plex 3351 1 3 20:27 ? 00:00:01 /usr/lib/plexmediaserver/Plex Media Server
plex 3377 3351 3 20:27 ? 00:00:01 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5263-f0d9679db /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/System.bundle
plex 3428 3351 0 20:27 ? 00:00:00 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.25.0.5263-f0d9679db 32600
plex 3581 3351 1 20:27 ? 00:00:00 Plex Plug-in [org.musicbrainz.agents.music] /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5263-f0d9679db /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/Musicbrainz.bundle
plex 3679 3351 1 20:27 ? 00:00:00 Plex Plug-in [tv.plex.agents.music] /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5263-f0d9679db /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/PlexMusic.bundle
plex 3709 3351 1 20:27 ? 00:00:00 Plex Plug-in [tv.plex.agents.movie] /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5263-f0d9679db /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/PlexMovieNew.bundle
plex 3713 3351 1 20:27 ? 00:00:00 Plex Plug-in [tv.plex.agents.series] /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5263-f0d9679db /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/PlexSeries.bundle
plex 3795 3351 2 20:27 ? 00:00:00 Plex Plug-in [com.plexapp.agents.thetvdb] /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5263-f0d9679db /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/TheTVDB.bundle
plex 3848 3351 6 20:28 ? 00:00:01 Plex Plug-in [com.plexapp.agents.imdb] /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5263-f0d9679db /usr/lib/plexmediaserver/Resources/Plug-ins-f0d9679db/PlexMovie.bundle
root 3874 1909 0 20:28 pts/0 00:00:00 grep --color=auto -i plex
Looks good-- Only comment is the OpenCL library as I wrote above is “ocl-icd” not “ocl-icd-libopencl1”.
It shouldn’t say “dpkg” but rather yum/dnf.
I’m also not sure how you are going to bypass Beignet-- but that’s going to be from your testing
ChuckPa
November 25, 2021, 1:54am
53
Do you have a CometLake / RocketLake ?
I can’t get it to work without Beignet .
I have fixed the above warning messages – that was “noise”.
It’s otherwise up and running with the new RocketLake-capable transcoder.
I do have a Comet Lake processor
ChuckPa
November 25, 2021, 1:59am
55
Care to spin up a new (test) server to avoid potentially contaminating your production and ride the wild software ?
Please check /tmp/plexinstaller.log. Its inventory should be exact.
Looks good from what I see:
# rpm -Uvh plexmediaserver-1.25.0.5263-f0d9679db.x86_64.rpm
Verifying... ################################# [100%]
Preparing... ################################# [100%]
Updating / installing...
1:plexmediaserver-1.25.0.5263-f0d96################################# [ 50%]
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Temp Directory: /var/lib/plexmediaserver/encdir (set in Preferences.xml)
PlexMediaServer install: Processor: Intel(R) Core(TM) i7-10700T CPU @ 2.00GHz
PlexMediaServer install: OpenCL: Installed
PlexMediaServer install: Intel Gmmlib: Installed
PlexMediaServer install: Intel IGC Core: Installed
PlexMediaServer install: Intel IGC OpenCL: Installed
PlexMediaServer install: Intel OpenCL: Installed
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: 1.25.0.5263-f0d9679db - Installation successful. Errors: 0, Warnings: 0
Cleaning up / removing...
2:plexmediaserver-1.25.0.5246-cb250################################# [100%]
# cat /tmp/plexinstaller.log
# Plex Media Server installation configuration info: Wed Nov 24 06:03:01 PM PST 2021
Systemd=1
Custom=0
LinuxContainer=0
NewInstall=0
HaveOverride=0
OverrideFile=""
PlexUser="plex"
PlexGroup="plex"
VideoGroup="render"
AppSuppDir="/var/lib/plexmediaserver/Library/Application Support"
PlexTempDir="/var/lib/plexmediaserver/encdir"
LangEncoding="en_US.UTF-8"
ExistingVersion=0
HaveHardware=1
HaveTranscoderPref=1
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=1
Errors=0
Warnings=0
HaveIntel=1
HaveIntelCore=1
HaveIntelXeon=0
Havei915=1
HaveNvidia=0
CPUSKU=10700
NeedOpenCL=1
NeedBeignet=0
NeedIntelCompute=1
HaveIntelGmmlib=1
HaveIntelIGCCore=1
HaveIntelIGCOpenCL=1
HaveIntelOpenCL=1
HaveIntelOCLoc=
HaveIntelZeroGPU=1
HaveIntelCompute=1
HaveBeignet=0
HaveOpenCL=1
Platform="To Be Filled By O.E.M."
Processor="Intel(R) Core(TM) i7-10700T CPU @ 2.00GHz"
Distro="Fedora Linux 35 (Thirty Five)"
Kernel="Linux rave.truevibe.net 5.14.18-300.fc35.x86_64 #1 SMP Fri Nov 12 16:43:17 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux"
Memory="31722 2513 729"
ChuckPa
November 25, 2021, 2:05am
57
A little bit of formatting to fix but otherwise looks good for fresh paintjob
But I’m still not able to do tonemapping which I just tested. I wasn’t sure if there is more for you to do to make that work: On quick look the logs said, Failed to get number of OpenCL platforms
ChuckPa
November 25, 2021, 2:12am
59
Grab the logs please (DEBUG) so I can take them to the transcoder team.
I think that’s a known problem they have with this transcoder update.
You had tonemapping before?
I tested with version 1.22.0.4163 and the tonemap works in hardware.
